Alarm arm beep code?
griswold Mar 8, 2010
  1. griswold
    griswold Member
    350
    How do i code the alarm to beep with vag com?
    done a search but nothing
    have coded anti hijack but not tested yet due to flat battery
    a6 avant 2.4 02
  2. griswold
    griswold Member
    350
    Update just added 1024 to the code now works
  3. Sam1909
    Sam1909 A6 2.5TDi
    Where do you add this to?
  4. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    Yeah, me too. Would like to add this.
  5. scott b
    scott b Active Member VCDS Map User
    1,254
    if its the same as the A4, then vagcom, into the coding bit, then i think it comes under the alarm section.
    if you want it doing give us a shout as not that far away from you i dont think
