  1. markie A3
    markie A3 Member
    149
    I know theres a specific air con section, but ive asked this question already..
    Will Vcds detect if the compressor isnt running, my aircon isnt blowing cool/cold air at all. I'm not really sure what kind of noise the compressor makes so a noise test isnt much help. AOnce again sorry to ask in the vcds section
    Thanks Mark
  2. a8 tech back
    a8 tech back Member
    198
    yes look in address 08 open label file look at compressor draw amperage for operation
    a/c gauges are better for diagnosis but mvb will show you whats going on and the system pressure as well from the readings at the pressure switch
  3. markie A3
    markie A3 Member
    149
    Thanks a8 tech......
    If its not running/faulting, will it show as a fault when the car is scanned?
  4. a8 tech back
    a8 tech back Member
    198
    unlikely unless you have low pressure because the comp is duty cycled so the signal will still go as the a/c pulley anti seize pulley breaks away if the pump is foobar.
    Check the line pressure in the mvb, even with the a/c off then there should be some pressure
    If you have sufficient pressure but the a/c will not start up without a fault code and the amperage stays constant then it normally indicates the pump but at this stage if pressure is present I would connect the a/c gauges to see a more in depth status
  5. markie A3
    markie A3 Member
    149
    Thanks for you help fella
    a8 tech back likes this.
  6. a8 tech back
    a8 tech back Member
    198
    no worries hope it makes sense
