Aircon Re-gassing
doeboy May 4, 2006
  1. doeboy
    doeboy Member
    602
    Mine's not Very cold, any ideas on avg prices and in particular any decent, cheap garages in Birmingham that can re-gas?
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Go to an aircon specialist (don't go to Audi). Should be around £70.
  3. CraigM
    CraigM Member
    100
    The last time I was in Halfords I noticed they were selling cans for topping up aircon systems - think they were about £25.
  4. doeboy
    doeboy Member
    602
    I'm not sure it needs doing to be honest. After a few mins it's pretty cold, not ice cold but still quite cold. I'm trying to work out whether that’s as cold as it should be.
    I had 2 courtesy cars 2 years back, a pug 206 first, about 8 months old, and a brand new fiesta. The 206 aircon was ice cold but the fiesta was similar to my A4 obviously the colder the quicker it climatises to your conditions.
    Anyone remember when they had their Audi regassed and how cold it was then and now?
  5. hop2407
    hop2407 Active Member
    1,408
    Audi Aircon or Climate is not ICE cold..... My wife had a Ford Mondeo and now a Focus and to be honest, they are colder than the Audi.... however, it should certainly feel cold when it's on - try having the blower on for normal cold air for a few mins, then switch on the A/C and there should be a noticeable difference.....
    Failing that, have a pressure test done with a reputable A/C specialist...
  6. doeboy
    doeboy Member
    602
    I think you've answered my question, thanks.
  7. AndyMac
    9,832
    46
    They do actually need regular servicing as anything goes faulty it gets expensive. Maybe worth getting an aircon guy to service it anyway.
  8. doeboy
    doeboy Member
    602
    Once i've found one that is!
  9. DIPS_A4
    DIPS_A4 SEAT LEON CUPRA R (225)
    570
    i had mine done by autotronics in leicester cost me £40 for a re-gas now its ice cold before i got it done it wasnt that cold nows it perfect some times i gotto put the econ button to make it go a lil warmer. let me know if u want the number.
  10. doeboy
    doeboy Member
    602
    Ok, found these guys, www.coolcaraircon.co.uk
    £49 for recharge, £59 for service and recharge.
    I'll take a look at the current fluid level, if it's correct and has not lost any then will a service really be benificial? I need to check the service book too when i'm home tonight.
  11. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,598
    3,172
    [ QUOTE ]
    [/ QUOTE ]
    What temp are you setting it at? Surely, if you're finding it a bit too cold, you should raise the temperature setting a bit, not switch it off!
    Don't forget, you're not trying to freeze-dry yourself. The idea is to set it at a comfortable temperature, say 20 or 21 degrees, and then leave it to its own devices.
  12. doeboy
    doeboy Member
    602
    i'm not mechanically minded guys.
    Having read various info from forementioned website i thought i'd check the coolant level, however i see no specific tank, however i do see the coolant tank for the radiator which is just a mil under the min fill marker.
    Does this tank supply the Climate system also?
  13. AndyMac
    9,832
    46
    The aircon relies on a pressurised system filled with Freon gas (like your fridge) I don't think it's something you can top up yourself or even check.
  14. doeboy
    doeboy Member
    602
    hm...so i'm non the wiser then, i'll just pay the £59 for service and topup and have peace of mind.
  15. joost
    joost Active Member
    1,169
    Mine cost £75 from stealers with full leak/electrical check and re-gas
  16. jdp1962
    8,598
    3,172
    [ QUOTE ]
    [/ QUOTE ]
    The coolant is the water system that cools the engine. It's nothing to do with the Climate Control.
  17. doeboy
    doeboy Member
    602
    Glad we cleared that up then! So where is the Climate harware behind the dash?
  18. AndyMac
    9,832
    46
    There's 3 main components to the system.
    The heat exchanger is buried behind the passenger airbag up high in the dash, then you have the pump and then the dryer which are in the engine bay
  19. JayB5UK
    JayB5UK Member
    471
    When the air-con is serviced they drain / release all the old gas and muck, then re-fill the gas with a quantity of oil also, to keep all the seals lubed to stop them cracking and hardening too. That sounds like a good price, have heard of people charging up to £100 down here!
