Aircon pump fail??
Cabbyfan Nov 13, 2012
  1. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Hi,
    Got to work this morning, car lumpy. Nice man from AA came out and agrees that aircon pump or clutch on aircon pump has failed. Car seems fine with aircon turned off.....
    Aido want £1200 to fit (luckly my local dealer is very good and gave sound advice), its a 2 hour fit but obviously I need the part.
    Any recommendations as to where to get one from ? SHort term I will fit a shorter belt to keep me on the road !
    Help much appreciated.
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    I fitted mine my self.
    Car on ramps and 2 hours or so later its fitted.
    Drove it to the AC garage and got it gassed up.
    I bought a 2nd hand pump for £60, £40 gas totaled to £100.
    That was 2 years ago now.
  3. Cabbyfan
    840
    34
    Hi Scott,
    Sounds good to me. Where did you find a pump ? Thanks for answering....
  4. ScottD3
    15,161
    1,121
  5. Cabbyfan
    840
    34
    Cheers Scott.
    Looks like I can get a compressor for under £150. Reading the ElsaWIn guide for the V6 it doesnt look terribly easy, seems to read take bumper off and move engine forward to service position yikes......
  6. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,195
    160
    Lost of cars use the same pump, simply swap over the pulley.
  7. Cabbyfan
    840
    34
    Looked at that, problem is I need my car for work so quite keen to get it sorted this weekend and I cant even get to the pump without bumper off and the whole service position thing which looks time consuming......
  8. renorti
    renorti Member
    40
    have an air con pump off a 1.8t 2002 model,{breaking my car for parts} should get to the pump from underneath but would be easier with bumper and radiators out the way, not to big a job I would say about 4 hours total.
    message if intrested in the pump .
  9. Cabbyfan
    840
    34
    I ordered one online from breakers for £123 inc vat and delivery. Got a local recommended independent fitting it for me on Monday so fingers crossed all be sorted next week.
    thanks for the replies guys.
  10. demus
    demus Fire in the hole..
    355
    19
    Don't worry about the service position, it really is quite easy, for once Haynes detail it quite well, takes about 20 mins and you'll need two lengths of M8 studding from memory, about 250mm long..
