AIRCON NO GAS??
AudiiduA Sep 15, 2010
  1. AudiiduA
    AudiiduA Member
    359
    Hi all, my aircon gas seems to be totally gone! but gone where??? any ideas fellas?:ermm: or can it just run out?
  2. rossbrownlee
    rossbrownlee Ross_S4
    719
    I was told that if you don't use the aircon for a while the seals in the air con compressor can dry out causing a leak but I don;t know if that is correct or not.
  3. barters3
    barters3 Member
    438
    This is true, there is oil within the refrigerant gases which needs to be circulated around the system to lubricate the seals. this is done by running the aircon at least once a month for 10mins or so.
    you will only have no gas in the system if youve got a monster of a leak (like i have!)
    Mine is leaking from a pressure switch which is located behind the rigid heat shield; behind the turbo.
    It has a diaphragm in it which i presume has failed. i found the leak by charging the system with nitrogen, this would obviously would need to be done by a specialist.
    it looks like a right pain to get to, so i will be taking mine to a garage to get it done.
    I dont know if it is a common place to leak but it may be worth mentioning if you take it in somewhere for a repair.
  4. barters3
    barters3 Member
    438
    may be worth posting in the airconditioning section of the forum aswell, good luck with it.
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    it is also worth mentioning that if the system is slightly low it will not work, mine only needed 50ml of the gas to be ice cold again, it is true about the oil in the gas and lubricates the system, another point of loss is the service pipe valves. my refrigeration engineer services mine and uses a sniffer around all the joints...and mine was fine.
  6. barters3
    barters3 Member
    438
    i am guessing you have had somebody put gauges on the car and youve been told there is no gas.
    as s3dave says if just a little is lost then it will go out on low presure and not run.
  7. AudiiduA
    AudiiduA Member
    359
    Cheers for all the replies fellas! i took off the black cap from the filler pipe and used a pen to poke the little valve and nothing came out!
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    My compressor switch has also gone porous. Not a hard job to do, although it looks it. The problem being that the switch is ~£50 from the dealer - which is a lot for what it is IMO.
  9. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    My system has a leak, has it regassed and they siad it was empty which they suspect was due to a leak, 2 weeks later its stopped putting cold air, havnt taken it back to be sorted yet but they added the dye so they should be able to located, hoping its not serious.
  10. s3dave
    10,110
    736
    What a waste of money, they should have pressure checked it with air to see if it was holding first...then fixed the leak source..
