Hi All,
I'm in the process of repairing the front end of our '97 A4 1.9TDi 110 after my girlfriend had a little accident in the snow before Christmas. One of the items that was damaged is the air-con condenser but I'd like some input before I decide on whether to replace it...
Basically, the aircon didn't work properly before the accident:-
I did get kwik-fit to empty and refill the system as I though it might have been low on refrigerant, but they ended up refunding me as a) I couldn't feel any noticeable improvement, and b) the printer on their machine was not working so they couldn't verify whether it had met the "10% improvement or your money back" criteria that they advertise.
A scan of the aircon ECU revealed no fault codes, the compressor clutch would engage and the compressor ran so it isn't siezed, and the condenser would get warm, but there seemed to be no noticeable cooling effect in the cabin. The two metal pipes that run down the right hand side of the engine bay would get warm and cool respectively but not hot and cold as I have observed on previous vehicles I have owned.
I'm really looking for any suggestions as to what the fault might be as I am reluctant to spend money replacing the now punctured condenser unless I stand a reasonable chance of fixing the pre-existing fault.
In addition whilst trying to remove the damaged condenser I have stripped the thread of the compression nut on the end of one hose and have still not managed to remove the other hose at all. They were both well and truly seized and even the liberal application of penetrating oil followed by the plenty of heat, cold, heat, cold routine did nothing to loosen them up.
The pipes seem to be constructed as one part with crimped joints between rubber and metal sections - if I cut the damaged compression fitting from the end of each rubber hose does anyone know whether an air-con specialist would be able to crimp on new ends?
Apologies for the long post, and thanks in advance for any info...
