Aircon help needed
Barton Dec 7, 2011
  1. Barton
    Barton New Member
    26
    Hi there. Ok here I go my a4 b7 avant has just started blowing constant cold air from the drivers side vents even though they are on high So I've been told that it is the flap motor on the drivers side but i cannot find it. Plz help as its getting cold out there now. Thanks.
  2. kite
    kite Member VCDS Map User
    677
    there are flaps on both sides, remove glovebox and/or lower trim on the drivers side.
    When you can see the flap motors operate the aircon and see which one is sticking.
    A scan with VCDS and going though basic setting may well reset the motor
  3. Barton
    Barton New Member
    26
    Hi i've removed the lower trim under the steering wheel but i can't seem to see the motor. can you point me in the right direction any pics or diagrams would be great.thanks again.
  4. Barton
    Barton New Member
    26
    [​IMG][​IMG][​IMG].Hi again i've put some pics from under my steering wheel on my profile..If that helps.
  5. kite
    677
  6. Barton
    Barton New Member
    26
    Thanks for that so are the three motors behind the glove box the ones that control the air flow to the drivers side aswel,as all three vents on the drivers side blow cold air
  7. kite
    677
    there are motors on both sides, check the operation of all of them...
  8. Barton
    Barton New Member
    26
    Sorry for bugging pal but is it just me in the thread you posted for me they refer to the motor under the glove box and I'm to believe mine are on the other side. All the pics on this subject seem to focus on the glove box side.
  9. kite
    677
    the motors on the glovebox side seem to be the ones that fail.
    Check the operation of all motors
  10. Barton
    Barton New Member
    26
    Thank for the advice pal I finally found the motor today and the yellow arm has broken off. Simple fix thanks again. Barts
  11. kite
    677
    glad the problem is sorted.
  12. Barton
    Barton New Member
    26
    Luck is not on my side this week just got the flap motor sorted then this afternoon on my way home the airbag light came on....... Have i knocked any wires under the steering wheel?.....what a month its been...thanks
  13. kite
    677
    check under seat connections and clear fault with VCDS
  14. Barton
    Barton New Member
    26
    Thanks pal just ordered my vcds cable...was holding out but can't keep nipping to local garage.Is it true that even if i have fixed the faulty lead the light will stay on until the code is cleared..
  15. ukdan
    ukdan Member
    72
    The light will stay on until its cleared with VCDS even if you have fixed the fault.
  16. Barton
    Barton New Member
    26
    Thanks all..
  17. Barton
    Barton New Member
    26
    Thanks pal very grateful..Barts
  18. wazz
    wazz Member
    89
    My mechanic just fixed the airing light in mine as well. was a bad connection under the seat. He also reset the diagnostics stuff as well so the light would go out.
