Airbag related question
Bradderz_1988 Apr 5, 2013
  1. Bradderz_1988
    3,947
    235
    Basically just been to pick the misses up from work snd some idiot flew out of a side street infront of the car in front of me so he slammed on and ive bumped his car and mine, my seat belt pre-tensioners went off on both front seats so i want to know can used airbag ecu's be plug and play or even coded to my car also if anyone is breaking a TQS have they got the following parts :-
    n/s/f and o/s/f seat belts
    airbag ecu
    o/s lower trim that goes under the front and rear doors were the seat belt anchor point goes through.
    also i need a o/s/f S4 bumper support bar as i think thats took most of the impact but will have to inspect it next week when back in work thanks in advance.
  2. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    If its not your fault then go through insurance?
  3. Mikemc
    1,024
    37
    Sorry just read it as you hit the guy who pulled out. Much damage to the car infront? Take it they sent going through insurance?
  4. Sulli79
    Sulli79 Active Member
    541
    37
    Have seatbelts and ecu still, I'm not good with near and offside, have the passenger trim though. I think the insurance company will just write it off as uneconomical to repair regardless of blame
  5. Bradderz_1988
    3,947
    235
    No ive said ill sort his car as im a mechanic and used to work for peugeot (his car was a 207sw) his bumper did its job and all it needs is the crash bar, think mine just needs the above oh and the o/s fog bulb back in the lamp unit lol
    as long as i get his sorted first ill get mine done asap the bumper isnt to bad on mine pending further investigation on removal hopefully dont need a new bumper :(
  6. Bradderz_1988
    3,947
    235
    Are the seatbelts differant between PFL and FL ??
    also any one know part number for the TQS airbag ecu on a saloon ??
  7. griswold
    griswold Member
    350
  8. Bradderz_1988
    3,947
    235
    Can this be done with vagcom ??
  9. Bradderz_1988
    3,947
    235
    Also is the trim im after the same for saloon/avant models ??
  10. Ian2012
    Ian2012 Active Member
    473
    29
    VCDS cant be used to erase crash data, you need the exact same part no for the airbag ecu ( don't i know i spent ages on this a month back) which if you can scan the car and communicate with it VCDS will tell you what the part no is, if not it's time to pull the climate control unit and radio out to have a look, i got my ecu from ebay for £5.00 used and fitted it worked fine and erased my codes.
    ian
  11. Bradderz_1988
    3,947
    235
    Cheers for the heads up ian will scan the car later and get the part no' so i get the correct one first time is it direct plug and play if same part number or is some coding needed for the ecu ???
  12. Ian2012
    473
    29
    it should be plug and play, mine was, part no will be something like 8D0 959 655 L no coding should be needed, might be an idea to jot down the workshop coding when you scan it!!
    Yours is easier to remove as you can get the ashtray out, saves shredding your wrists like i did, i ended looking like a self harmer!
  13. griswold
    griswold Member
    350
    Problem buying airbag ecu off ebay might have a controller error 65535 which that reset tool can remove but vcds can't. the cold mornings at 5.am puts my light on just have to clear later but ok when warmer weather.. Also someone called sulli600 just cancelled my bid for an airbag ecu for no reason. I used the tool to clear crash data from wifes A6 so they do work.
