Airbag light on....
a4cam Oct 17, 2008
  1. a4cam
    a4cam New Member
    14
    Well the airbag light has come on , had codes read by a mate , its a faulty igniter , he thought that the pins on the seatbelt pretensioners could be a little corroded , so have had the B pillar trim off , cleaned the pins up in the plug , put it back together . The light is still on .
    Has anybody else had this problem ? Or is htis a common fault , any help would be appreciated
  2. 951
    951 Member
    530
    Its usually the conector under the drivers seat that causes the problem.
  3. docurley
    4,073
    88
    And you will have to use VAGCOM to reset the air bag as it will not go out until it's reset even if you fix it.
  4. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    also AndyMac kindly pointed out to me that If you dont deal with the light and if you have any other airbags in the car they will not work until you have cleared the warning light.
