Airbag Light! Just come on....grrr
Hardsy Oct 8, 2007
  1. Hardsy
    Hardsy Hardsy_S3
    59
    Hello,
    After recently purchasing an s3 and being a big kid and sitting in the seats and playing around with the electrical adjusting the airbag light came on. I think its probbaly something to do with me messing about with the seat.
    Just wondered how to get it to stay off!
    Hope you can help,
    Thanks,
    Nick
  2. AndyMac
    9,832
    45
    You need to reset it with VAGCOM, if it comes on for any reason (unplugging any of the wiring with the ignition on) then it will stay on even though the fault is not there anymore. All airbags are disabled until you do a reset.
  3. Hardsy
    Hardsy Hardsy_S3
    59
    how do i go about doing this?! do i need to take the car somewhere?
  4. Hardsy
    Hardsy Hardsy_S3
    59
    anyone?
  5. jojo
    28,846
    3,509
    You need someone with diagnostic equipment, usually vagcom, to reset your airbag light.
  6. grathies
    grathies More Points Than Portsmouth FC
    1,343
    If its not that then it could be a dodgey crash sensor, seen them randomly go alot in the past
  7. Tooks
    Tooks Active Member
    753
    29
    If it happened whilst you were fiddling with the seat, then it's more than likely something to do with the little loom under the seat that goes to the in-seat side airbag.
    It's a common fault on cars built on this platform, both the drivers side one on my Golf MkIV and my current 8L have had this.
    If you're lucky, it has just come undone, but it's probably just starting to fatigue from the seat being moved backwards and forwards over the years and the resistance has got higher as a result.
    Easy enough to fix though, you can buy the loom from a dealer, although you'd still need VAGCOM or similar to turn the light off.
