Airbag fault diagnosis...? VCDS scan included.
Fahim Apr 15, 2011
  1. Fahim
    Fahim Member
    278
    Hi,
    I have had an airbag fault on my car for the last 6 months or so, and finally got round to scanning it for a fault. I do NOT need an ear bashing for driving around with the fault, i just need help to find out whats failed and how to repair it etc.
    If you would still like to help, then i refer to the VCDS scan.
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 0036M002CN1Q
    Coding: 0033622
    Shop #: WSC 06325 000 00000
    VCID: 3B7168C70317
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 254
    Time Indication: 0
    Any information?!
    Thanks for any sensible replies given,
    Fahim.
  2. Fahim
    Fahim Member
    278
    Actually, its ok. I've googled my search query and came up with numerous posts just like mine. Possibly the wires under the seat, but perhaps not. I'll get it looked at tomorrow.
    Thanks for looking.
    Fahim.
  3. NHN
    29,523
    1,766
    Wiring issue I'd say, check connectors in floor & in seat, common issue.
  4. Fahim
    Fahim Member
    278
    NHN, sorry but where is the connector in the floor? Underneath the carpet somewhere i take it? The seat one seems fine..but i'll double check in the morning.
    Thanks for your reply.
  5. NHN
    29,523
    1,766
    No disrespect mate but its kinda obvious when you get your head under there with a torch, follow the wires, also can check in the rear panel as there are connectors inside the seat at back, but cant see them disconnecting easily, check underneath 1st.
  6. Fahim
    Fahim Member
    278
    Cheers! :)
