Air vent removal
Keefy Apr 26, 2010
  1. Keefy
    Keefy Member
    139
    Hi all,
    Yesterday noticed there's a rattle coming from the passenger side air vent as I go over bumps - on closer inspection it appears that a tiny shard of plastic has broken off the inside of the vent grille and is rattling around in there somewhere. I've had a poke around with some long pliers and tweezers but to no avail. Looks like the vent is going to have to come off.
    Had a little pull but it's not budging. I'm not sure if it's just a bit stiff or if there are clips that I've missed? Not keen on trying too much harder as I don't want to make a mess of the interior. Looked on some of the vent-based boost gauge threads but there's no info on actually removing the vent grill. Should I just give it some or is there a special way of removing them?
  2. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,821
    105
    I asked this a while back,
    So the thread should be somewhere... basicaly it involved making 2 hooks that just fit through the gaps in the vent... one top and one bottom. they latch over the back of the vent housing ( about 3 inch inside the vent ) and this allows you to pull the vent free. If a search brings you no results i will take a picture later and upload it
  3. Keefy
    Keefy Member
    139
    Found it after quite a bit of searching, cheers!
    Here's the link if anyone else needs the info: Removing drivers air vent
  4. finesse
    finesse Active Member VCDS Map User
    2,805
    :detective2:
  5. ZeroOne
    ZeroOne New Member
    17
    I just have bought Audi A3 1999.. The passenger air vent is borken, can someone help me how to change it?
  6. anderswhk
    anderswhk Member
    214
    How is it broken Zero? Wont open, or air wont come out?
    ZeroOne likes this.
  7. ZeroOne
    ZeroOne New Member
    17
    mn6S1UPILizTp5z_8Pi2Svg.jpg one of this are broken.. so how can I remove this all, not just the part which is broken..
  8. ZeroOne
    ZeroOne New Member
    17
    Do you understood me ?
  9. anderswhk
    anderswhk Member
    214
    You need some trim removal tools, which is usually red plastic and you can gently take it out. Then the entire unit comes out. If you have a facelift A3 (With red lights in the vents) you will need to do some solering. Shouldnt take any more than 15 minutes.
    ZeroOne likes this.
  10. ZeroOne
    ZeroOne New Member
    17
    But some pictures or video, what kind of trim removal tool ?
  11. anderswhk
    anderswhk Member
    214
    It is just pieces of plastic to remove plastic trim such as the dashboard without scratching and damaging it.
  12. ZeroOne
    ZeroOne New Member
    17
    How looks that pieces of plastic?
  13. anderswhk
    anderswhk Member
    214
    just google trim removal tools
