Air quality sensor
s3reptdi May 30, 2013
  1. s3reptdi
    s3reptdi Member
    179
    Did a search but couldn't really find anything. Got a fault code for Air quality sensor, anyone every changed one? Where are they? Roughly how much and is it best to use genuine or doesn't it matter?
  2. NHN
    29,331
    1,716
    Its under the plenum chamber, I cant recall which side, possibly passenger side.
  3. s3reptdi
    s3reptdi Member
    179
    is that under the dash or the bonnet? No idea what the plenum chamber looks like?
  4. s3reptdi
    s3reptdi Member
    179
    Found it, passenger side, didn't even need to remove the scuttle panel, part number 4B0 907 659 A?
  5. NHN
    29,331
    1,716
    Yeap.
  6. s3reptdi
    s3reptdi Member
    179
    Any idea how much they are? Are they dealer only? There over £30 second hand
  7. Boon
    Boon Active Member
    441
    59
    Have you changed the pollen filter? As I had a fault with the sensor on VCDS, changed the filter, cleared codes & it's not come back!
    Might be worth trying?
  8. s3reptdi
    s3reptdi Member
    179
    No I haven't but I will do, on eBay second hand theyre going for around £35 just rang TPS they're about £22! Ridiculous what some people think they can charge!
  9. NHN
    29,331
    1,716
    Depends on the fault tbh, if its a no communication, which I've found numerous times, then its a duff sensor or wiring given the sensor is actually external & are you sure its that sensor & not an internal one as there are various ones in the ducting for this system, as this ones mounted externally so one would assume (even if assumption is the mother of all.................) it checks the air coming in pre-filter, not saying this isn't your case, but it would seem strange for the pollen to affect a sensor that's open to the elements as such, if it was post-filter then I could see how it would restrict air & the sensor would maybe read things wrong with no correlation of readings, speculative as not sure how the logic is derived, but hey with cars never can discount something unrelated :)
  10. s3reptdi
    s3reptdi Member
    179
    Uh oh so there's more than one air quality sensor? How do I know this is the right one?
  11. NHN
    29,331
    1,716
    No I didn't say there are more air quality sensors, just other sensors in general.
