air filter question??
nath-w May 19, 2010
  1. nath-w
    nath-w Member
    141
    Today while i was replacing my dipstick guide which i broke whilst doing my thermostat, i thought i would quickly check the air filter as i havnt owned the car long. Anyway it was filthy. I did think my car was a bit sluggish for a 1.8t, so i took it for a nip down the road with the airbox unclipped, and wow what a difference, cant believe how much more responsive my car was, and i could even here the turbo.
    Anyway now i want a new air filter, but not sure whether to get a panel filter for standard box or get a cone filter. Also if i got a cone filter what would i do with the sensor thats screwed to the side of the airbox? Found this a bit strange as i used to own a 2001 s3 which didnt have this sensor on the airbox?
  2. S3 Johnny
    S3 Johnny The grass isn't always greener
    271
    17
    Green Cotton Panel Filter All The Way Mate :thumbsup:
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    or jetex cone....
  4. <tuffty/>
    21,957
    4,229
    ...its an ignition amplifier... later coil packs have all this built in to them (which makes them even more prone to failure)... you just need to re-mount it somewhere... I think its mounted to a heatsink? can't remember off hand... couple of others (Alpine, A3Tom) have done similar I think...
  5. nath-w
    nath-w Member
    141
    So does it not matter where I remount it the engine bay, or does it need to be near or inside some type of cold air feed?
  6. Matt82
    Matt82 Active Member
    2,365
    or just get another paper one!
  7. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Stock paper one has proved time and again to be the best.
  8. fingermouse
    fingermouse thats me
    4,030
    120
    I just use oem changed every 10k ish
  9. ALPINE
    3,093
    this is what you want :)
  10. Matt82
    2,365
    and it costs pennies and it filters PROEPRLY
  11. S3 D2HTY
    S3 D2HTY Member
    122
    What induction kit is that?
  12. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Screw the Ignition Amp to the plastic wiring casing that runs down behind the air box with small self tappers. Thats what I did - worked a treat.
  13. ALPINE
    3,093
    its one i developed for the 1.8T lump. has direct cold feed running to the filter and is in a nice cool place. Heat shield`d pipe going to the maf and fannys ya uncle. cold air and lots of it. Proven figures i posted on here works a treat. sounds nice too :)
  14. S3 D2HTY
    S3 D2HTY Member
    122
    What parts did you use?
    Where did you source them from?
    Thinking doing the same on my S3 . . .
  15. ALPINE
    3,093
    local sources, got cold air feed from a place in essex via ebay, custom made plates made either buy myself or by my pals at the steel works. you can get simalar bits off the bay but i found them to be quite sh1t quality. Filters i get from a local tuning shop/factory. there Simota filters.
  16. S3 D2HTY
    S3 D2HTY Member
    122
    Cool cheers for the info
  17. nath-w
    nath-w Member
    141
    Did you have to move the battey as my battery is close up to the wing, so theres no room to put a cone filter beside it?
  18. ALPINE
    3,093
    yep i moved the battery. only by about 3" tho
  19. Bigphil92
    Bigphil92 Member
    61
    what did you do about the oil breather pipe?
  20. ALPINE
    3,093
    mine dont have a oil breather.. but for those that do just pop a mini filter on it. shimples!
