air escape ?
jay1601 Dec 17, 2010
  1. jay1601
    jay1601 Well-Known Member
    1,347
    73
    hi,
    for the past few days it sounds like its got a bird under the bonnet (annoying whistling noise)
    opened the bonnet today, i can hear air leaking from somewhere near the turbo/DV/intake pipe
    is there any common faults near this area
    also sometimes it will also idle at 1200-1500RPM (not all the time)
    not sure if this is linked at all
    thanks for any help/info
    Jay
  2. Nilz
    11,364
    903
    Its very regular and common for the pipes under the bonnet to perish and deteriorate, it could be one of many, just do a feel/visual check, it cleary sounds like there is a vac leak somewhere....
    Spray some carb cleaner around the area, if you notice the revs changing, you may be able to find the leak a little easier.
  3. jay1601
    1,347
    73
    still reading -20 to -24 on the boost gauge
    would the standard DV leak air ?
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Possible, but it's the change in revs that's interesting. Typical of a leak.
    I would recommend replacing all the hoses in that area. Good practise anyway to avoid future leaks.
  5. A3 Oly
    A3 Oly Member
    247
    Right so i am thinking 98 a3 1.8t's shouldnt make a kinda whistling noise on idle?
  6. hatchs3
    hatchs3 New Member
    9
    NO they shouldn't. From experience check the air inlet pipe - which is past the MAF unit. There is a crankcase breather return pipe which comes into this main moulded pipe from the side, check that there are no splits in the region of this join. At this point the air is unmetered - so the mixture will be very very lean . I know - I had 8 new exhaust valves about 2.5mnths ago. Check the condition of the other hoses from the crankcase breather - the oil vapour will degrade the hoses (excess oil vapour is probably worn valve guides).
    Hope this helps.
  7. jay1601
    1,347
    73
    good info Hatchs3 i will check mine asap
    :icon_thumright:
  8. A3 Oly
    A3 Oly Member
    247
    Ditto, thanks Hatchs3 i will do the same although its a wee bit dark now.
    Hey jay, Same a3's me and u gold and 98 and 1.8t....... :)
  9. jay1601
    1,347
    73
    does yours say "yellow" on the log book aswell ?
  10. A3 Oly
    A3 Oly Member
    247
    Yep lol
    Is it more liquid yellow than gold? i aint sure, but it certainly aint yella!
  11. A3 Oly
    A3 Oly Member
    247
    Actually bout u and i having same year etc, have u had a remap? and was it an **** to get done? as i have had problem after problem getting it done but just waiting for revo to sort right harness out for my ecu. I have the agu lump.
  12. jay1601
    1,347
    73
    mine is 1999 (T)
    its being remapped after xmas
    but i am not going to Revo, i'm going up to R-tech to have it done, cheapier and get alot more for your money
  13. jay1601
    1,347
    73
    i found out the problem.
    fitted my Forge 007P today, as i took the vacuum pipe off the top of the DV, i noticed the hose was split where it joined the metal rail from the inlet manfold.
    replaced with a silicone hose, and its stopped the air noise.
  14. Nilz
    11,364
    903
    Good stuff, glad you got it sorted mate.
