Air conditioning not working???
Wheeler97 Mar 8, 2009
  1. Wheeler97
    Wheeler97 New Member
    10
    Today i tried to turn my aircon on but it just won't.When i press the button symbol indicating aircon comes on, and as soon as I release it is gone. :sos::wtf:
  2. kaizokuninja
    kaizokuninja Member
    145
    could that mean it needs re-gassing? i'm a n00b so its just a suggestion=)
  3. Haglos
    Haglos jabba mapped
    247
    mine also does this but then other times it works perfect
  4. s3ollie
    s3ollie Member
    762
    i think it wont come on below a certain temp as the airs cold enough already. mine does it too
  5. Lenny Benford
    Lenny Benford snowed under
    167
    Yes what Ollie said, if its below a certain temp the air con will not come on, i think if you have the* displayed on the outside air temp it will not work.
  6. Wheeler97
    10
    But if you press button with windshield icon it should also start the aircon, at least that used to happen
  7. Dani_B19
    9,465
    435
    Get it on vag com and see what comes up
  8. AS3TOM
    AS3TOM Member
    190
    for the aircon symbol to stay on the outside temp has to be above 5degrees
  9. hooley
    hooley Member
    199
    Also check the fuse on top of the battery
    Mine went and knocked out the fans and air-con
    J.
  10. Wheeler97
    10
    You were right, after a night in garage it started working. The outside temperature does matter. :salute:
  11. stickertone
    stickertone New Member
    24
    this is silly though isnt it.. when you want the a/c to demist the windows you cant because the outside temp is too low.
  12. con1.8t
    con1.8t New Member
    17
    I have the same problem and find it hard to stop the windscreen misting up without the aircon . Is this directly linked to the air temp sensor ? if so where is it and can anyone think of a way to fool it into thinking its a bit warmer because I'd rather have a clear screen than know if its a bit cold outside.
  13. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    It doesn't just do it for fun, it's to protect part of the A/C system (can't remember which bit), but it's an important design feature.
  14. <tuffty/>
    21,961
    4,229
    ...you could go oldskool and just direct hot air too the windscreen... just a thought :)
    A3/S3 aircon has a windscreen defrost button that does it for you too...
  15. barters3
    barters3 Member
    438
    My brother is an ac engineer and he told me that it will not run in cold weather,as if it did then it would cut out on low presure. The presure of the gas in the system is affected by ambient temp. So this is why it is interlocked with the outside temp sensor.
