Air Conditioning fuel consumption and full drinking features
brad9753 Jun 22, 2013
  1. brad9753
    brad9753 Member
    78
    For the first time this year, I was reminded how much my fuel gage falls when the air con is on. It's a 03 corsa, so I am assuming the technology has improved, has it?
  2. dav63
    dav63 Member
    73
    22
    the engine!
  3. Headlights, fog lights, heater fan, heated rear/front window, wipers, radio if amped, hazards, fag lighter, heated seats....
  4. Jeff777LUFC
    Jeff777LUFC Member
    84
    12
    Yes :) the climate control is so good you will want to leave it on all year round. So you won't notice the extra fuel it uses when you switch it on.
  5. dieseldoug
    dieseldoug Member
    240
    53
    Wear and tare, lack of dealership servicing, if the costs bother you you need to purchase a cheaper build vehicle from another manufacture. Or a pedal bike which AC will be free, lights on dynamo, loose the membership to the gym and hire a car for the long drives, then your costs will drop....
    SJW and Daveotto like this.
  6. h5djr
    9,372
    1,723
    I read an article a couple of years ago which said a car uses more fuel if it is driven with the windows open that with the air conditioning switched on. The main time when a little more fuel may be used is when the compressor in engaged and this only happens when the system is asking for cold air. It has an electronic clutch and is only engaged when required.
    Personally I have my a/c switched on all the time. The car is always at the right temperature and I never have steamed up windows.
