  1. vr6gordy
    vr6gordy Well-Known Member
    2,809
    187
    had aircon regassed in jan and today i noticed its blowning warm air at me on the lo setting anyone got an idea ?
  2. quattrojames
    14,050
    577
    Impossible to know where to start with that information. You'll need to let us have some more...
  3. fallmonk
    fallmonk Turbo Sport
    1,868
    Doubt if its used it up that quick,
    Unfortunately it might be something more sinister , I had a stone Kill my air con radiator hope this isn't the case for you
  4. Mike B
    Mike B Well-Known Member
    1,101
    40
    If it was OK after the regas it may be a leak or if the pipes into the bulkhead are cold then a flap maybe stuck.
  5. glenandem
    glenandem Active Member
    686
    31
    Does the econ switch turn on and off?
    if it does I'd be looking under the bonnet seeing if the compressor coming on,fans working and check ac pipes see if one side gets cold Etc!
  6. Rudedaubin
    Rudedaubin Member
    78
    9
    Check the filler valves are not leaking, had mine regassed recently and the machine could find no leaks in the system, so after it was refilled we dropped some water onto the valves with the caps off and sure enough they were slowly leaking.
  7. vr6gordy
    2,809
    187
    i can turn the switch on and off ok when pressing the the button you can here the air slow down and press again to turn the light off and the air speeds up
  8. Pedro07
    Pedro07 Newbie
    15
    sounds like i'm having the same issue did you find the problem?
  9. vr6gordy
    2,809
    187
    all fixed now turned out when i had it regassed in jan it had a leaking presure switch so time i put new presure switch in all the gas had leaked out had it regassed the other week and its blowning lovely cold air at me now
