Air con smelling funny after thermostat change
Jay Jul 13, 2008
  1. Jay
    Jay Member
    318
    I had my stat changed a few weeks ago and now the air blowing out of the air con smells funny (kinda toxic). I thought it would go away after a bit but its still the same. The only way I can describe the smell is the smell produced when the ECON button is used. It still heats/cools as normal.
    Anyone know what it could be or how to clean the air blowing out?
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    new pollen filter?
  3. Jay
    Jay Member
    318
    Had this changed when I had the timing belt done. About 12K miles ago.
  4. themanthatcan
    themanthatcan Member VCDS Map User
    661
    I get that smell as well when pressing the ECON button..kinda like stagnent water? I was of the assumption that it needs a new pollen filter. Was planning on replacing it at the same time as getting the CC regassed.
    I'm thinking that it was just coincidence that you started getting the smell around the same time you changed your thermostat.
  5. j4jon
    j4jon Member
    704
    Is it possible that the pollen filter has got wet in the past and thats what is causing the smell?
