Air Con Smell
Marc1 Sep 18, 2008
  1. Marc1
    Marc1 Member
    728
    Hi, there noticed my aircon keeps smelling when I first put it on. Doesn't matter what temperature, it stinks either way.
    Smell is quite musty at first, have also noticed a kind of cat wee smell.
    Have thought it maybe the panel filter that needs changing, but I draw a blank after that. Any ideas would be greatly appreciated, thanks.
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    Someone recently posted something similar but I can't find it or remember what the outcome was.
    It's not the air con internals of course. Is it only when not in ECON mode? It could be a dirty evaporator.
  3. PW-Motorsport
    PW-Motorsport Member
    396
    There is a bacterial spary produced by Worth that should help.
    It is sprayed into the airbox via the water drain use a whole can per car.
    Make sure you vent the car after as it is a strong solvent cleaner.
  4. denzelburner
    denzelburner Member
    166
    May I suggest that you could use Comma air con cleaner from ebay. I used it last year on mine, when it was getting a bit bad, and having done the panal first, it cleans it up a treat. It's anti-bacterial, so it should get rid of those smells :icon_thumright:
  5. Awesome_Andy
    Awesome_Andy New Member
    20
    I'd recommend changing your panel filter and carrying out an aircon clean
  6. Marc1
    Marc1 Member
    728
    Thanks for your help guys. I'll carry out both suggestions. I've seen some K&N Panel filters for the B6 A4, is there really any point to them over the standard factory fit or is it a waste of money?
  7. Staz
    6,206
    65
    I think you're getting confused. When Andy says the panel filter he means the air system filter. I think you are refering to the engine air intake filter, it's a different thing.
  8. dollface
    dollface Member
    33
    yes i have that cat pee smell , thought it was cat being nasty and pissing in my car , found out aircon needed cleaning audi did for me cos i said it smells of **** lol
  9. tuneus
    tuneus New Member
    AIR CON SMELLS SUCH AS MUSTY/DAMP/CAT PEE. ARE CAUSED BY EVAPORATOR CATCHING ALL SORTS OF CRUD,THINK ABOUT IT! IF U SNEEZE -FART-EAT-AND ALL OTHER THINGS WE DO IN OUR CARS IT HAS TO BE SPREAD AROUND BY AIR SYSTEM,SOUNDS HORRIBLE -BUT THIER IS AN ANSWER--CHANGE CABIN FILTER PANEL AT LEAST YEARLY, AIR-CON EXPERTS CAN USE A CLEANING STSTEM(WYNNS) WHICH WE HAVE FOUND TO BE EXCELLENT.
    WE ARE BASED IN ROCHESTER KENT FOR TUNING AND AIR-CON
    OUR LAUNCH PLATFORM WILL RE-CODE PARTS TO AUDI/VW.
    THE COMMA PRODUCT MENTIONED ON THIS SITE IS USEFULL BUT DROPLET SIZE IS TOO LARGE AND ENDS UP ALL OVER SEATS/INTERIOR.
    THE PRODUCT WE USE IS TURNED INTO A GAS BY OUR APPLICATOR.
    HOPE THIS HELPS
    REGARDS
    TUNEUS:redrs4:
  10. tuneus
    tuneus New Member
    HOPE THIS HELPS
    REGARDS
    TUNEUS:redrs4:
  11. abdus
    abdus Top Gear VCDS Map User
    1,827
  12. Marc1
    Marc1 Member
    728
    Air con smell has gone, washers stink now though, grrrrrr!!!!!!!!!!!
  13. everogere
    everogere New Member
    19
    I just brought a 2005 A4 and noticed a cat wee smell. It turned out to be old water in the washer bottle. Ran it through with fresh water and a dash of disenfectant and that cured it !!! Refilled with screen wash, problem not returned.
  14. SixDegrees
    SixDegrees Member
    73
    Change the pollen filter as well. Did mine and smell much reduced. Now for some anti-bac spray to complete the job.
  15. gizm0
    gizm0 Member
    187
    hi guys, i know this is an old thread but where do i spray this anti-bac stuff? it says the air inlet but not sure where that is :/ lol
    cheers
  16. gino260169
    gino260169 New Member
  17. makindue
    makindue New Member
    Hi gino. I like your links. I am browsing for a good products. And I think they are good. :D
