Air Con Service
malcolm1sim Jul 26, 2006
  1. malcolm1sim
    malcolm1sim Member
    42
    Morning All,
    Time for an Air Con service I feel. Car is 4 years old.
    Anyone know of a good company in the Croydon
    (south London) are.
    Thanks.
    Malcolm
  2. bubstar
    bubstar Member
    550
    Try Turners in Imperial Way
    BUB
  3. malcolm1sim
    malcolm1sim Member
    42
    Thank you, will check them out.
    MDS
  4. Merlot
    Merlot Member
    44
    How frequent are you meant to do this? My three year old S4 is getting a bit smelly so probably time. What does an a/c service involve over and above a re-gas?
  5. malcolm1sim
    malcolm1sim Member
    42
    I have to say that I am not really sure.
    Presumably, all joints/seals etc are checked, even if only visually,
    the system cleaned, re-gassed and filter changed.
    My understanding is that there is no such thing as
    a perfect seal, as light (as in not heavy) gases can escape molecule
    by molecule. If that is true then over 4 years or so
    a fair bit can leak away.
    If there is an expert out then who can add/put me
    straight I would be grateful.
    Malcolm
  6. marmite
    marmite Counting the Tesco Club points
    1,101
    The system will leak gas over a perod and some get used.
    Manu recommend every 2 years and now recommend Anti bacterial agent run through the system after a year, well worth it.
    On a/c sevrice they should, that is should drain the gas, check for oil removed while doing so, evaquate the system 15 - 30 min, pulls out any moister and vacumn the system, regas put some leak dye in it and do a temp check. 10min
    they should look around for leaks or signs of dye too.
    I recommend replace pollen filter too as if your doing anti bac on evaporator best change filter other wise your just going to suck **** straight back in.
    Def worth doing I do mine every year, regass and antibac
  7. Merlot
    Merlot Member
    44
    Thanks - very helpful
  8. malcolm1sim
    malcolm1sim Member
    42
    Ditto
    Malcolm
  9. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Cheap way....
    Go to halfrauds, buy a can of R134a and a can of Comma Air Con antiBac, then follow instructions on both products, this will regass and clean your air con, and save you over 100 quid.
