air con returns to 23 degrees all the time?
kryton Nov 1, 2012
  1. kryton
    kryton Member
    91
    10
    hi all,
    as above really the air con on my 2000 s3 always returns to 23 degrees when i start the car. will it not stay on the temperature i left it at?
    I havnt had the car long and my old a3 didnt have aircon,
    cheers kryton
  2. Filth
    Filth Member
    106
    Im not sure how tor resolve it but I think it should yes as mine stays at what it was left on
  3. Gops
    3,197
    666
    Are you using the same key? The climate stays on a desired temp due to the key aswel! If you go to HI and then switch the fan off, it'll go to a certain temp - that's what mine does
  4. kryton
    kryton Member
    91
    10
    ok thanks will try that , been using same key
  5. Nilz
    11,318
    870
    Mine always stays on whatever I left it at when switching the car off. I do always switch it off before switching the car off though, so not sure if that makes any difference at all or not.
  6. aragorn
    18,020
    716
    The settings are stored per key.
    So if i get in, set it to 21c and ECON, then the missus gets in and sets it to 18c with AC and full blowers, when i get in again with my key, it returns to 21c and ECON.
    Perhaps theres a comms or coding issue between the climate unit and clocks, so the climate unit doesnt know what keys being used?
