Air con pump sensor
Jab XL Aug 15, 2012
  1. Jab XL
    Jab XL New Member
    Hi ive got an Audi A3 2.0tdi and the air con pump senor plug is broken on the pump side does anyone know if you can get the sensor separate? the pump ive got on is p/n 1K0820859F. thanks for any help.
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,267
    202
    That sounds like a N280 valve connector. Is the aircon working? Have you run VCDS to see if you've got a N280 fault code?
  3. Jab XL
    Jab XL New Member
    Thanks for the reply I've not run a vcds on the car an the aircon pump isn't workin at the min cause cant connect it the car was a cat d before I got it an the plug was broken off the pump when the damage happened, the plug on the harness side is still intact tho its just the sensor on the pump I need but can't seem to get a part no only full aircon pump which are far to much money! :(
