Air Con Problems
Discussion in 'A6/S6/Allroad forum (C5 Chassis)' started by danny104, May 3, 2009.
  1. danny104
    danny104 Member
    Apr 30, 2009
    44
    As normal the weather improves and the Air Con packs up. I have read the memory using vag com and get the following fault code : -
    Sunday,03,May,2009,21:26:45:26365
    VAG-COM Version: Release 704.1
    Address 08: Auto HVAC
    Control Module Part Number: 4B0 820 043 F
    Component and/or Version: A6-Klimavollautomat D61
    Software Coding: 00064
    Work Shop Code: WSC 02325
    1 Fault Found:
    00792 - A/C Pressure Switch (F129)
    31-10 - Open or Short to Ground - Intermittent
    Once the fault is deleted the Air con works again, for a little while!!!
    Has anybody had this problem / know how to fix?? I think it is what it says the A/C Pressure switch has packed up and needs replacing, is this easy??
    Any advice would be good !!!!!!:banghead::banghead:
