Air con problem
doublem_1 Jul 14, 2013
  1. doublem_1
    doublem_1 Member
    500
    I have a 52 reg A3. It has the digital climate control. However, what with this warm weather there is a bit of an issue! The air con on the coldest setting is blowing out luke warm air. The gas is filled up, fuses fine. Last summer it worked a treat. Anyone had a similar issue?
  2. carl-1968
    carl-1968 A4 sold, lots of bits available, ask for details
    538
    30
    check compressor clutch?, friend of mine has similar issue with A4, have you run vcds to check for any faults?
  3. doublem_1
    doublem_1 Member
    500
    Not checked any codes yet. How do I check the compressor clutch? The engine not does change slightly when changing from air con to econ.
  4. carl-1968
    538
    30
    The engine should load up, i.e your should hear a deffinite click as the compressor kicks in and this is sometimes accompained with a change in revs the A/C fan may also cut in as well, depends on the system demand, I hate to say it but I believe halfords do a free check on the A/C system and if they cannot fix it there is no charge, but check this out before letting them look at it, hope this helps out?
    Carl
  5. Mikey3000
    Mikey3000 New Member
    20
    Exactly the same problem my friend. I work with a lot of brand new cars which really highlights the difference in performance of air conditioning between my 14 year old A3 and those. I get warm air at best from mine - absolutely killer in this weather :(
