Air con problem on friends new car .
RMH1A4cab Aug 13, 2011
  1. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    549
    19
    Hi all , wonder if anyone on here could help.
    A mate of mine has today bought a 2004 1.9tdi SE 130 BHP Avant , drove the 100miles back from the garage with no problems , he rings me tonight to say the air con is not working so I call could to take a look.
    The problem is the econ light will not go out and the air being blown out is cool but nowhere near cold enough , I have tried everything to get it to turn off but with no success , anyone with any ideas .
    Thanks .
  2. quattrojames
    14,045
    570
    The ECON light will come on by default when the system has a fault, this is in effect isolating the compressor so it doesn't get damaged. The system could be low on refrigerant, or there might be a fault with a pressure switch for example.
  3. RMH1A4cab
    549
    19
    Thank you for speedy reply , would I be able to find the fault via vcds so I can pin point the problem.
  4. simon.m
    simon.m Active Member
    2,747
    vcds will tell you most problems with the air con not sure if it will say about it being low or not thought
  5. RMH1A4cab
    549
    19
    Thanks for that , i'll have a look tomorrow I hope its not anything to bad he only picked it up today .
  6. simon.m
    2,747
    well mine dont work and when i scan it it dose not show any codes at all and my econ light works fine but compressor is not coming on.
  7. quattrojames
    14,045
    570
    First thing to do is take it to an aircon specialist and get them to test the pressure of the refrigerant, you'll instantly know then whether low refrigerant is to blame.
  8. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    I'll hazard a guess that its just low on R134a or empty. A specialists machine will tell you instantly if there is refrigerant in there. A healthily topped up system, with the correct amount of R134a in, will be 5bar on both low and high side ports. Anything below about 2 bar, and the low pressure switch will prevent the compressor from switching on.
  9. RMH1A4cab
    549
    19
    Thanks Gary , ill get it to my mates garage and get it checked out .
  10. gary3306
    989
    40
    Pity you aren't closer, I would have sorted it out for you. Hope it just turns out to be a simple re-gas and nothing more costly.
  11. RMH1A4cab
    549
    19
    Thanks for the offer Gary but your right you are a bit far away :).
  12. simon.m
    2,747
    where abouts are you gary
  13. RMH1A4cab
    549
    19
    Finally got my mates car on vcds , threw up this fault.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63251
    VCID: 60CA0797CAD3
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
  14. simon.m
    2,747
    i had the High Pressure Sensor on mine was about £35 about 2years ago from audi easy to fit its in the right hand side/ns of the aircon rad head light needs to come out to change it and then just unscrew it no need to worry about gas as none comes out.
  15. RMH1A4cab
    549
    19
    Thanks for that simon,from what iv'e read over the last hour it seems to be a common problem.
    I Will fit a new one and get it re gassed at the same time , hopefully that will sort it .
  16. simon.m
    2,747
    yeah it is very common i did mine in the hope it was just that but im not that lucky lol
  17. RMH1A4cab
    549
    19
    Oh dear that doesn't sound good what was wrong with yours , i hope my mates is an easy fix as he's only had the car a few weeks ..
  18. simon.m
    2,747
    i still have not got round to fixing mine looking like its the compresor
  19. RMH1A4cab
    549
    19
    Ouch that sound expensive .
  20. simon.m
    2,747
    yep one of the resons iv not done it the othere is we live in the uk and thats the best thing to get rid of the heat from the sun ;-)
  21. gary3306
    989
    40
    Sorry Simon, only just seen your post. I'm in Ashington in Northumberland. About 16 miles north of the TOON! :sm4:
  22. simon.m
    2,747
    no wories mate bit far for me as well
  23. bouffont
    bouffont New Member
    Hello, I'm a newbie to this forum but have a very similar issue. I drive an A4 B7 2.0 TDi 170 and I have the same fault code as RMH1a4cab, no a/c and econ always on. However, I also have a noticeable clicking noise behind the head unit which is most prominent when the ignition is on but car not started. I bought the car in Dec 12 and its only now I'm realising the a/c isn't working. Any ideas? Could the preasure sensors cause the clicking? Gary3306, I live in North Tyneside!
  24. Cabbyfan
    Cabbyfan Active Member
    840
    34
    The clicking is probably the motorised flaps that direct air flow on the aircon etc they all do it. I would scan it and see what comes up.
  25. bouffont
    bouffont New Member
  26. Cabbyfan
    840
    34
    I would say this is a good place to start http://i.imgur.com/9N0UMBj.png
    seaech on here for the fault code and also the sensor number there are loads of threads on it as its quite s common fault. As fir the other fault codes not really an expert but if you google he fault code or look it up here it will point you in the right direction . Use this link Category:Fault Codes - Ross-Tech Wiki
  27. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Don't chase any faults till you've cleared them then scanned again in a few engine cycles. Apart from the pressure sensor, they have only occurred once so unlikely to be any problems.
