Air con immediate on/off???
bentleyboy Jun 22, 2009
  1. bentleyboy
    bentleyboy Guest
    Is there a way to turn your air con on or off without having to repeatedly tap the + or - buttons??
    Annoys me when it's on full blast and want to turn it off but have to press the - button 20 times before it finally switches off! And vice versa for when it's off and I want it on full blast.
    :confused:
  2. dc240969
    dc240969 Member VCDS Map User
    925
    lm sure if you press - for a few seconds it should turn off.
  3. bentleyboy
    bentleyboy Guest
    I thought I'd already tried that and it just came down through the blower speeds until it went off.
    I want it to just switch off straight from the blower speed that it's at, and switch back on to the same speed.
    But cheers, I'll give it a go again.
  4. dc240969
    925
    lf it doesnt work and it isnt in the handbook it might be doable through VAGCOM.
  5. bentleyboy
    bentleyboy Guest
    Couldn't see it in the handbook.
    Pretty silly IF they haven't given us that function as standard though.
    Most things have a simple on/off button, don't they!! :wacko:
  6. dc240969
    925
    that is true. lm not one for reading the handbook either
  7. a_sagad
    a_sagad Member
    119
    The A3's don't have the ON/OFF button, so you have to go through the fan speeds. :(
  8. Lee_R
    Lee_R Active Member
    2,499
    12
    The blower speed is dependant on the temp its set at. If you have it on too cold the blower is always on trying to cool it down. Try upping the temp a few degrees and you will notice the blower not going so mental.
  9. a_sagad
    a_sagad Member
    119
    The best thing would be to turn AUTO off and then the fan will not go full blast when ever you change the temperature.
  10. bentleyboy
    bentleyboy Guest
    The blower speed is only dependant on the temp when you've got it on auto. When not on auto it just blows out air at which ever speed you have it set to, regardless of the temp setting.
    Oh well, looks like my FSI is going to give me an RSI because of the amount of times I'll have to press the +/- button.
    Audi, very poor!!! :(
  11. dc240969
    925
    Dont dispair, as l said you might be able to do it with vagcom. give iggu, jamiekip or nhn.
