Air Con Guru Required
A3-Lee Jul 29, 2014
  1. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Hi currently working on a audi a3 8p 2004 with climatronic the ac does not work and i have this fault code from vcds.
    00797 - sunlight photo sensor (G107)
    009-Open Circuit or short to ground
    i have replaced the sensor with a new part from tps and the fault still will not clear also how can i tell if the ac pump is running as it is supposed to run all the time so cannot check for clutch kicking in I have also noticed the cooling fan isn't running either with climate on
    All input welcome
    Thanks Lee
  2. Gaz-M
    Gaz-M Member
    170
    20
    Is the Econ working as it should, not stuck on? Im not a guru but im willing to attempt to help. :p
  3. j4yvw
    j4yvw Member
    50
    Hi I had a recent aircon issue. Had econ light intermittantly on so had it regassed but still the same, I looked into the forum and found common issue is the g65 pressure sensor fails the problem with mine was that the senseor was leaking internally. I have changed the sensor and had the car regassed and all is good now.
    Make sure you have checked and cleaned the relevant aircon fuses and contacts first before moving to changing parts.
  4. A3-Lee
    938
    226
    43
    Right I've checked all fuses - all good
    System is re gassed and has a new pressure sensor econ works as it should and vcds sees the ac off signal when econ pressed cheers lee
