Air Con fan killing battery.
otis_b Jan 7, 2008
  1. otis_b
    otis_b Member
    30
    Whenever the ignition is turned off on my B6 1.9 Tdi , the air con radiator fan comes on and stays on therefore killing the battery.
    My friend ran VAG-Com on it and it came up with the following error code:
    01206 - Signal for Duration of Ignition: OFF
    27-00 - Implausible Signal
    Any advice or suggestions would be appreciated.
    Otis
  2. donvas
    donvas New Member
    27
    Poss two faults.
    1 faulty rad fan ecu unit
    2 water inside e box housing which can short out fan relay depending on engine spec
