Air Con Drip Normal?
Markadrian Jun 16, 2010
  1. Markadrian
    Markadrian New Member
    Hi folks Im a newbie here so please forgive a dumb question maybe. I have recently bought an R reg A3 with a 1.8 engine. This morning I have small puddle of water on my drive, its definately water and doesnt taste of antifreeze.
    It appears to be coming from the right front lower spoiler area below the rad. and lower rad hose. The rad and hoses appear dry with no leaks. Im therefore wondering if this is some sort of drain for the air con? Is it normal?
    Thank you in advance
    Mark
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Sounds like the rad tap leaking to me. Air con pump is over the other side of the engine, so I can't see it being that.
    Have you got headlight washers?
  3. 1animal1
    9,978
    Mark are you talking right front from in the car or looking from the front :)
    im guessing the leak is below the battery area?
  4. Markadrian
    Thanks for the replies its the right side of the car as I stand infront of it ie an offside leak. Theres no headlight washers on my model.
  5. Welly
    10,696
    130
    Have a look at the rad tap first then.... That's where it live, on the bottom at the back of the rad.
  6. Markadrian
    Thanx Welly I will recheck. I ran my hand all round there this morning and all felt dry. If it was from the rad tap wouldnt the water taste foul from the anitfreeze as it does in the top up bottle? There is a pipe coming over from the air con pump thingy down to the general area of the leak. Let you guys know how I get on, thanx so far.
  7. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,305
    375
  8. Welly
    10,696
    130
    I would guess so, he put quite a bit in that bottle according to that article. if there was only a inch of coke, and 2 inches of anti-freeze on top, then that must be 150 ml.
    Talk about a prank gone wrong....
  9. Alex C
    3,305
    375
    yep, bet he feels pretty bad
  10. Welly
    10,696
    130
    He will do when he's getting buggered by bigger boys for 7 and a half months (which is what he will likely serve).
    Don't drop the soap pal.... Bon Voyage.
  11. Markadrian
    LOL, nah it was only a finger taste. Well ive had a look and the rad tap is dry, the water has evaporated from the drive without staining. No antifreeze lost when looking at the expansion/fill bottle. Back to the drawing board I guess.
  12. Alex C
    3,305
    375
    lol, no i didn't expect that you'd got to your hands and knees to lick the tarmac dry :)
  13. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    I was about to mention the "doesn't taste like antifreeze" comment, but will now refrain.
  14. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    If it's straight water then it will be the climate control, run the car for 10 minutes on a hot day or so with the A/C on and it will **** water out. The A/C system takes all the moisture out of the air and it has to go somewhere, totally normal, nothig to worry about. There's no other area of an engine that will leak pure water.
