Air con code for coolant temp??
S3 Dave Apr 22, 2008
  1. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    When using the air con codes. What is the number for coolant temp???
    I think its 51 can anyone confirm????
    :confused:
  2. NoggyDS3
    NoggyDS3 Member
    192
    Its 49 on mine mate.
  3. jonS3
    jonS3 Member
    719
    I think it's 51 actually, 49 just goes up to 90 slowly and stays there. or it could the other way round, you'll know by looking tho
  4. 1animal1
    9,978
    what are you talking about with the air con????
  5. NoggyDS3
    NoggyDS3 Member
    192
    Sure it's 49 on mine as i used it very recently as i was having probs with temp/thermostat. Maybe it can vary? Like you say, best bet is to check and see!
    Animal - if you press the 'recirc' and 'up' buttons together on the climate control unit it should show '1c'
    Then press the temp '+' or '-' buttons to choose a code for checking various values (in this case either 49c or 51c) Then press the 'recirc' button again and it should show the value for the for the coolant temp.
    There's a few things u can see, RPM, speed etc.
  6. 1animal1
    9,978
    brilliant, didnt know about that...... i take it these values remove the usual climate reading? also how do you revert back to the climate
  7. NoggyDS3
    NoggyDS3 Member
    192
    yea - it removes the climate figure. You just press recirc or auto to put it back to normal.
    The fan speed buttons work as normal in either mode though!
  8. 1animal1
    9,978
    so if the coolant temp is 49....then does that mean i have to click 49 times?????
  9. NoggyDS3
    NoggyDS3 Member
    192
    Pretty much... unless you go backwards (can't remember what the highest code number is...) Either way, 49/51 is as near as dammit in the middle!!!
    Or, you can just press and hold to save clicking! only takes about 10 secs.
  10. 1animal1
    9,978
    okies....so you can view, speed, rpm, temp..... whats the other 46 options?:think:
  11. NoggyDS3
    NoggyDS3 Member
    192
    There's more than 49! Not sure what all of them do but there's temps from various places all round the car: interior/exterior also loads of potentiometer values for god knows what! Think it's basically everything the CC needs to know to operate efficiently.
    But certain ones are just good for a cheap way of diagnosing some wee problems!!!
  12. 1animal1
    9,978
    ahhhhhhhhh cheers for that noggy...will have a go on my way to work in the morn:beerchug:
  13. NoggyDS3
    NoggyDS3 Member
    192
    No bother, think 27c is RPM for interest if you're playing, and sure 49c is ECT on mine.
    Will check tommorrow and post back for Dave.
  14. grathies
    grathies More Points Than Portsmouth FC
    1,343
    Anyone got a definitive list of what positions what?
  15. grathies
    1,343
    Found from a previous post by Kevint
  16. 1animal1
    9,978
    so no speed in MPH.........
  17. grathies
    1,343
    No, thats why you have a speedo infront of you :p
    Not gonna me much different accuracy wise anyway dude, their reading from the same sensor
  18. 1animal1
    9,978
    just curious lol
  19. grathies
    1,343
    Not another curious one!
    Go join Nick and Ibzzzzzzz in their Curious thread dude :p
  20. NoggyDS3
    NoggyDS3 Member
    192
    Weird... Just checked on my car and my ECT is 49 and my RPM is 27 - Obvioulsy not gone through all of them but mine is def different to that list Grathies!?!?!
    :uhm:
  21. grathies
    1,343
    :p
  22. NoggyDS3
    NoggyDS3 Member
    192
    Mine must be special...! :whistle2:
