Air box noise/chatter ?
Quattro180 Jan 3, 2011
  1. Quattro180
    Quattro180 Member
    99
    I have recently been hearing a funny noise coming from the airbox/intake area? It sounds like a chatter or suction noise. It only does it when coming off the throttle. Car seems to be running ok but maybe using more fuel than usual? Any ideas?
  2. quattro1
    quattro1 Member
    639
    your diverter valve is broken or the little vac pipe on it has split
  3. Quattro180
    Quattro180 Member
    99
    sorry to ask a stupid question but could you try and tell me exactly where the diverter valve and the little vac pipe is? i assume that it is attached to the air intake pipe?
    cheers
  4. Quattro180
    Quattro180 Member
    99
    Does this help?
  5. Az
    Az Hard slammed!
    1,040
    35
    My car does exactly the same! The previous owner had my car remapped so I always assumed it was due to that, and I've had loads of work done on the car by audi/vw specialists who have taken the car for a test drive after they had carried out any work on it and they have never said anything about it, so I assumed everything was as it should be. But now it's got me wondering too as soon as the diverter valve and pipe have been mentioned. My car wistles and sucks a lot under acceleration too.
  6. Quattro180
    Quattro180 Member
    99
    It just doesn't sound right to me, unless anyone else knows different? The car seems to be using slighty more fuel aswell.
  7. Quattro180
    Quattro180 Member
    99
    I am taking the car to a garage on Saturday and will report back
  8. Az
    Az Hard slammed!
    1,040
    35
    Good man!
  9. C17LJR
    C17LJR Member VCDS Map User
    513
    my mapped 180 does the same,
    sounds almost like a distant police siren when i accelerate?
  10. Az
    Az Hard slammed!
    1,040
    35
    Haha! Yeah it does! I like it, and always get comments about it from mates and passengers, my step daughter calls it the jet car. :)
  11. Higgsy
    Higgsy Hard To Spin
    96
    on the 1.8T the diverter valve is at the bottom of the engine behind the offside foglight, should have 3 hoses coming out of it, not too sure about the 2.5 though, if its goosed or a hose has split, you should be able to see it from there.
  12. rawtor51
    rawtor51 Active Member
    355
    47
    Anyone else get this , my 130 does it , i had it into Audi and they said not to worry about it
  13. marktdisport
    marktdisport Active Member
    1,195
    15
    my standard 130 also does it......... just a noise of the turbo coming off full spool id say......
  14. simon.m
    simon.m Active Member
    2,747
    i have this sound too did not have it when i first got the car over two years back any one have a pic of a diverter valve and where it would be on tdi 1.9 so i can have a look ;-)
  15. rawtor51
    355
    47
    I was really worried about it to start with but Audi assured me I shouldn't worry about it, thay said some do it and some don't, they wouldn't turn away custom surely if somthing was wrong, so since then I don't take any notice of the noise, I was just curious to see how many other folk had the same.
  16. Widemonkeys
    Widemonkeys 1st Gear
    271
    Mine used to do it all the time, now it's stopped but my car also constantly goes into limp mode
  17. tdia4
    tdia4 TDIPOWARRR
    613
    The tdi does not have a diverter valve.
    My tdi 130 does it as well, i've asked before and it seems many other people have it.
  18. pbwatch
    pbwatch Member
    30
    I suffer this too on my 2.5tdi 180 but I also get a louder air rush noise and a noisy turbo under load when it is playing up! I have been told by a Turbo specialst and that it could be a cat issue creating more back pressure and causinbg the egr valve to remain open and cause the chatter when I ease off the throttle!
  19. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    sticky actuator on the turbo,
  20. iyrix
    iyrix Member
    460
    12
    Mine has done this since I had a major service. Not been too worried about it, but if it's something to fix I will.
  21. Turkster
    2,811
    54
    we had a thread on this one a while back, its a sticking actuator valve thing, i had this on my car, so i swapped my whole turbo unit over with actuator and the problem was GONE! ended up being the actuator,
  22. rawtor51
    355
    47
    Ah sweet , gives me somthing to look at ,
    Thanks.
  23. iyrix
    iyrix Member
    460
    12
    Yeah same, need to have a look t some point.
  24. jonny_mcc
    jonny_mcc Member
    40
    this just started happening on mine last night when i reversed it into my parking space. Does anyone know if the actuator can be swapped without changing the turbo?
    J
