Air Bag Warning Light
imported_gek May 4, 2005
  1. imported_gek
    imported_gek Guest
    Hi All
    Had a 2 to 1 alarm upgrade done yesterday and since I picked it up the Air Bag warning light on the dash and the passenger light above my head are both on.
    Vag com reports the following:
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8L0 959 655 J
    Component and/or Version: Airbag Front+Seite 5008
    Software Coding: 01104
    Work Shop Code: WSC 01236
    1 Fault Found:
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    30-00 - Open or Short to B+
    Any ideas? The car is still under warranty but I'm thinking Audi might blame the alarm installer. Should having an after market alarm effect the warranty?
  2. Little_Si
    Little_Si Member
    62
    Sounds to me as if the person fitting it has removed the glovebox and not reconnected the airbag disable switch when putting it back together.
  3. imported_gek
    imported_gek Guest
    Is that something I can check myself or is it a bugger to remove the glovebox?
  4. Little_Si
    Little_Si Member
    62
    Should be able to do it yourself.
    There are a few screws, most of which are abvious. I'll have a look later when I get home for the exact screw (torx headed) locations.
  5. imported_gek
    imported_gek Guest
    Thanks Si
    Also, out of interest, what do all the little buttons do behind the enable/disable airbag keyhole?
  6. imported_gek
    imported_gek Guest
    and another question....!!
    Having done some more digging, I've read some threads where they say the passenger airbag can be reconnected, but the light remains on, and needs to be reset.
    Anyone know whether this is something I can do with vag.com or is it a dealer only thing?
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    it can be done with vag-com. mine doesnt have the key hole must be due to being a 1998 model
  8. imported_gek
    imported_gek Guest
    [ QUOTE ]
    [/ QUOTE ]
    Is there more to it than clearing the fault code as that does not do anything.
    The fault just reoccurs when I switch the ignition off and on.
  9. Little_Si
    Little_Si Member
    62
    Here's some instructions how to remove the glovebox. You can at leat confirm whether the switch is connected or not.
    Click HERE
    Si
  10. bham a3
    bham a3 New Member
    20
    Hi I have just brought an a3 1.9 tdi 110 sport, and I have only just noticed that the passenger air bag light comes on, I have tried switchin it on and off to see weather it makes a difference but it doesn't. Could any body help me with this please
  11. a4rider
    a4rider Member
    44
    Did he ever sort that out? I'm having the same fault code. where is the airbag disable switch ? i cant see mine??
  12. ARtechnik
    ARtechnik New Member
    15
    Glove box doesn't need to be removed to just pop the side panel off with a small flat screwdriver and see if the switch is connected
  13. a4rider
    a4rider Member
    44
    Ah ok all connected and good. I doubled checked. Any other solutions.
  14. <tuffty/>
    20,904
    3,713
    Fault codes?
  15. a4rider
    a4rider Member
    44
  16. Erikn89nl
    Erikn89nl Well-Known Member
    697
    255
    Damaged wiring behind the glovebox?
  17. a4rider
    a4rider Member
    44
    damaged wiring which one lol there are so many wires?
    the airbag and glovebox are in good condition - i cant see anything. i can take it out on the weekend and make sure all the wires are good.
    do you have any other suggestions
  18. a4rider
    a4rider Member
    44
    Can anyone assist? How did he resolve the issue?
