I have a 2004 2.0 tdi a3 and the airbag light keeps coming on and off (not flashing) just some times on and then will go off for abit! Do you guys know any common problems and solutions?? Thanks cal
Ideally needs scanning to verify which airbag is causing the light.
But, common ones, check under the seats to see if the connectors momentarily coming loose, if not this then inside the back of the seats is next pit stop.
