Air Bag light permanently on - Audi want £264!
mancdan Mar 21, 2012
  1. mancdan
    mancdan Active Member
    497
    51
    Just picked my car up from Audi Stockport as it had the coil packs replaced under recall notice.
    I asked them to check why the airbag light was permanently iluminated in red (as opposed to amber) and they have put on the paperwork " requires the wiring repairing under the O/S/F seat £264 inc"
    Exactly how much wiring do they replace and how big of a job is it?
    Is this something I could do myself if I buy the necessary part or not?
    I am waiting for N8 to find out how to remove the light with his VCDS, however if I can fix it myself then I would consider replacing the part(s).
    Thanks all, Daniel.
  2. hades-
    9,482
    646
    iv had this a few times very comon
    1st off make sure its pluged in nice and tight
  3. mancdan
    497
    51
    Thanks bez, I take it the plugs are easy to locate under the seat, and it is the passenger seat?
  4. hades-
    9,482
    646
    its usaly the drivers side
    but can also be the pass seat
    pull seat all the way back u will see a black cover there inder there
    yellow plug is the bag
    if that dont work its the wireing prety easy to do and alot less that what audi want
  5. chrisa4quat
    chrisa4quat Active Member
    970
    29
    That's expensive. Only and hours work roughly
  6. mancdan
    497
    51
    Have checked both plugs and they seem to be in tight and firmly. Air bag light is still on though.
    What is involved with the wiring and what is needed?
  7. mancdan
    497
    51
    Thanks Chris, any idea what parts are required and rough cost?
  8. hades-
    9,482
    646
    light will stay on even when fixed needs to be turned off
    did u get the code from audi ?
  9. S3 GAZ
    S3 GAZ Member
    381
    17
    Yeh common fault on all VAG cars. Get under the seat from the rear and locate the yellow multiplug on the airbag loom. Separate it and clean the contacts. Put back together and reset with vagcom.
    Did the trick on my b6.
    If the yellow multiplug is goosed then Audi solder the wires together bypassing the plug.
    Hardly worth £270 of your Eurodollars
    If I recall correctly the airbag system will be inactive whilst there is a recorded fault. Might wanna get it sorted ASAP.
  10. stuartyp
    stuartyp Member
    59
    i had this problem with both my seat's. I put a 4.7ohm resister across the wires under the seat's then turned the light of with the computer and it hasnt came on yet.if you need any more info pm me
  11. mancdan
    497
    51
    Hi Bez, I didn't get the code from Audi but am waiting for N8 to get more info on how to turn the light off with his VCDS.
  12. hades-
    9,482
    646
    its a 2 min job with vcds
    if you was near to me i would have done it
  13. mancdan
    497
    51
    Where are you based Bez? N8 said he is not sure on how to do it and is getting further information from his contact.
    (I have also asked him if he can set the auto window closure with key fob too - so maybe he is also getting info for this)
  14. hades-
    9,482
    646
    im in sheffield
    but do travel to s wales every weekend
  15. mancdan
    497
    51
    To be honest I would come over to Sheffield if you can remove the light as I'm sick of seeing it!
    Are you able to program auto window closure as well?
  16. hades-
    9,482
    646
  17. mancdan
    497
    51
    Excellent guide indeed and very simple job to do. Took me approx 30 mins and seat bolted back in perfectly.
    Thanks again Lee.
  18. hades-
    9,482
    646
    oh just 1 thing when audi told you did they say what side it was
    as it can happen to both drivers and pass seat ?
  19. mancdan
    497
    51
    Yes they put on their paperwork O/S/F which I hope is passenger side, but now I'm thinking its drivers side...eek!!
  20. hades-
    9,482
    646
    i know i read that after
    im thinking drivers is the offside
    anyway its only a 30 min job
    and ill see u sunday txt me when you leave so i rember
  21. S3 GAZ
    S3 GAZ Member
    381
    17
    Drivers side is offside. Passengers is
    Near side
  22. stuartyp
    stuartyp Member
    59
    audi said my 2 front seats needed replaced because the connector's where bust. This was suggested to me and has worked. As for the bag's not going off the only ones that wont will be the seat one's... And one more thing you dont know me so dont be calling me a dickhead ..dickhead
  23. murran
    murran Well-Known Member
    1,545
    39
    if its only the connections then cut the plugs off and solder the wires together. job done.
  24. hades-
    9,482
    646
    i cant see anything wrong with him calling you
    you not solveing a problem the advise you gave could have been bad if he did it and crashed
    as above plugs off wire up they still work 100%
  25. stuartyp
    stuartyp Member
    59
    i wasnt told about cutting the plugs out and putting new ones on... Audi said new seats and i was told i could do the resistor's... Now i know about the plug's i can now change them...
  26. hades-
    9,482
    646
    you dont change the plugs you cut them and bin them
    and you belived audi why ?
  27. murran
    1,545
    39
    what was your original fault code? can you remember? did it say high resistance or low resistance?
    low resistance it needs a new airbag unit.
    high resistance in 99% of cases its a wiring problem. usually the plug under the seat. but i had one once where the wiring within the seat had chaffed thru where it passes from the seat base into the seat back.
  28. hades-
    9,482
    646
    it was high
    he did away with the plugs and wired up
    i cleared light tonight and it stayed off
    so fingers crossed it will stay off for good
  29. mancdan
    497
    51
    Many thanks for your VCDS help last night Lee, very much appreciated and I would recommend your services to other forum members.
  30. hades-
    9,482
    646
    no probs nice meeting you
    and a very nice A4 you have there
  31. murran
    1,545
    39
    oh cool youve met up and sorted it out? thats brill.
  32. lenti
    lenti 7th Gear
    87
    39
    had the airbag light problem to, asked Audi they wanted me about the same price, but noway tot hat, i did check the DIY that is posted above, and looked again on the connections and did se that the Airbag connector was not in place, so i did just plugged the connector and the used VAG to remmove the light, after 2 days the light came again, so i did purchas e a new connector did cost £3 and replaced it, now it has been 6 weeks and no light had come :)
  33. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,293
    640
    We're in Stockport if you need any help in the future!
    Rick
  34. mancdan
    497
    51
    Thanks Rick, do you have some contact details so I can keep a record?
  35. Rick @ Unicorn Motor Dev.
    1,293
    640
    No problem :)
    Unit B2 Safestore
    61-63 Wellington Road North
    Stockport
    Cheshire
    [FONT=Arial, Helvetica, sans-serif]SK4 1HS
    [/FONT]0161 480 7171
    [FONT=Arial, Helvetica, sans-serif]My colleague Spencer does a lot of airbag repairs, seem to be getting very common now,
    Rick
    [/FONT]​
