Air bag light on...
boya Jun 18, 2011
  1. boya
    boya Member
    384
    Any common reasons for this? Its a 2003 saloon 2.5tdi fwd. Cheers for any info!
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,284
    2,100
    Dodgy connection-my mates A3 had the light on so we pulled them apart (no ignition key in) then reconnect and all was good
  3. S3 GAZ
    S3 GAZ Member
    381
    17
    yep yellow connector under driver or passenger seat usually the culprit. youl need vagcom to reset the airbag light though.
  4. Avant4me
    Avant4me The're Graphite not black!!
    257
    is it safe to use vag com on air bag modules? mine always displays a warning about accessing these modules
  5. hades-
    9,482
    646
    you can use vcds on any modules
  6. boya
    boya Member
    384
    sorry for the late reply, i gave the car a clean yesterday and found the wires under the plastic cover, so it is deffo safe to remove them with no key in the ignition? cant be ***** with a dozen airbags going off lol!
  7. hades-
    9,482
    646
    yes its safe
  8. boya
    boya Member
    384
    Cheers mate, I will try it tomorrow!
  9. S3 GAZ
    S3 GAZ Member
    381
    17
    make sure you got the right yellow connector though. its not usually the ones on the floor its the ones up under the seat. i found it easier by going under the seat from the rear. i just pushed them together tightly. and reset with vag com and voila!
  10. boya
    boya Member
    384
    Cheers mate, I had a look yesterday and I was planning on tackling the ones on the floor!
  11. mlody
    mlody Member
    184
    I had the same problem, kept pushing them together, even sello taped them together just so that they are tight but no joy. I ended up cutting the connectors off and soldering the wires from the seat directly to the wires in the floor
  12. S3 GAZ
    S3 GAZ Member
    381
    17
    Yeh that's what Audi & VW do if you take it to them
