"Air Bag Light on" What is this Fault Code ? Help ?
J.R. Jan 23, 2011
  1. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    This airbag light came on the other day. I don't know where to check this and what it is. Also does this mean the airbags won't work now that this light is on the dash ?
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0011602
    Shop #: WSC 06435 000 00000
    1 Fault Found
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    its prob a dodgey wire under the drivers seat make sure its plugged in good
    very common
  3. J.R.
    1,405
    68
    Do you know if it's this bit of the wire I have to check?
  4. hades-
    9,480
    646
    pull that black cover up
    u have wires under there
    im prety its the yellow plug for the bag
  5. J.R.
    1,405
    68
    I've looked at it and it's plug in right and no loose wires...So I cleared the code and went for a little drive....as soon as I pulled into my drive the light came back on. :sadlike:
  6. PaulTheo
    PaulTheo Member
    126
    Remove and refit it a few times this will clean the contact area it only needs a slight change in the resistance to trigger the air bag light and fault code. I had to do this every 5 to 6 months on my B5.
  7. NHN
    29,284
    1,695
    If you had to do every 5-6 months then contacts needed a rub with a jewellers screwdriver or the like to give it better conductivity IMHO, as for your issue on 8P, yeah I'd do the same on that aswell, but iirc there is a connector in the seat aswell that the airbag plugs into the seat loom, need to remove the rear cover which isnt that hard, get some fingers behind at the top, slowly but with some force prise it of about an inch or 2, then reach down with a long screwdriver or whatever & push the other clips to the side which should inturn release the rear cover, lift up & of as the covers have hooks at he bottom, dont snap these of or new cover needed, thats from memory which should be correct.
  8. Clivesportback
    Clivesportback Member
    53
    this light is on now on my car :( i have played around with the yellow plugs, but with no joy :( any other ideas? it seems the wire goes to the back of the seat how do i get the rear seat cover off?
  9. NHN
    29,284
    1,695
    The light wont go out without a diag tool to clear it even if connectors are pushed home/fixed.
  10. Clivesportback
    53
    bugger :(
  11. J.R.
    1,405
    68
    Come down to me and I can turn it off......but it could come back on ....like what's happening to me.
