Air bag light on dash
Gt Tdi_ Mar 8, 2013
  1. Gt Tdi_
    Gt Tdi_ Member
    32
    Can't remember...may have moved seat back on runner but air bag light is on.
    Thinking i should check plug at under seat then perhaps take battery off - will this clear the fault 'air bag' on dash or is this likely to be more (sensor or something then needing vagcom to clear/reset)?
    Any ideas, cant imagine the sensor's go faulty...more likely cable/push on clip has been disturbed surely?
    Any help much appreciated if it saves a garage bill!
  2. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Prob under seat loom or connector.
  3. Gt Tdi_
    Gt Tdi_ Member
    32
    if i push the connector on will this get rid of light on dash or do i need to dis-connect battery or have fault cleared (assuming it's just been disturbed)?
  4. Cabbyfan
    840
    34
    Prob best to clear but the dash light should go out I believe.
  5. Mike B
    Mike B Well-Known Member
    1,115
    40
    I think you need VCDS to clear
