ok, something weird has happened, got home from work this morning and had a play, managed to somehow blow the rear brakelight fuse (brake lights didn't work after this!) Basically I took the relay out with the ignition on and all sorts of warning symbols appeared? replaced relay and replaced fuse, and now the warning symbol i am getting is for the front brake pads, but I know 100% my brake lights were working before with the brakelight warning symbol coming up (and yes the fuse was good when I checked!)??
when I turn the ignition on it goes straight to the brake pad warning light with a beep,this does not flash like the brake light symbol I had? or maybee it was alternating between the two and the lcd couldnt keep up, making it look like a flashing brake light symbol? my dis display is a bit liney.
Sooo, the drivers side pad has no wear indicator to connect to, but the passenger side does and is connected? here is the source of the warning light now methinks.
but why is there no wear indicator on drivers side?
