Air bag light just came on
Agent_Trig Dec 14, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    It just came after coming back to my car. Was only gone 5 mins haha
    What does this usually mean? Quick fix or a pro job?
    Cheers :)
  2. Ash187
    7,486
    738
    could be anything, depends on why the light actually lit up in the first place.
    get the car scanned to check for errors and reset the light. See if it comes back.
  3. warrenlord
    warrenlord Member
    771
    15
    guessing its a 3 door?
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    My money is on drivers plug.
  5. Ash187
    7,486
    738
    LMAO... good guess... after looking at his sig :lmfao:
  6. Agent_Trig
    Agent_Trig Member
    552
    Yeah why?
  7. warrenlord
    warrenlord Member
    771
    15
    :blink:
    Well you have a loom on both sides for the front seats.. If you have been pulling the seats back and forth quite a lot it can loosen the connection on them and the air bag light can come on.
    Happend to me, secured connection and removed the light.
  8. Agent_Trig
    Agent_Trig Member
    552
    Ahh I see.
    Is the loom underneath the seats and easy to check and secure?
  9. warrenlord
    warrenlord Member
    771
    15
    Yeah should be ok..pull the seat about half way back and pull the look forward. Have a look for fraying wires or loose ones. You will need someone to then turn the light off for you.
    Un bolt the wires on the battery FIRST so there's no current in.
    Just in case lol
  10. Agent_Trig
    Agent_Trig Member
    552
    Right ok, just to make sure I've got this right...
    1 - Disconnect battery
    2 - Check cables and reconnect if necessary
    3 - The light wont go out once reconnected? Does this need to be done via VCDS?
  11. NHN
    29,333
    1,717
    Quite a common fault tbh, as already suggested, just check connectors under the seat & you'll need vcds anyway to remove the light.
  12. warrenlord
    warrenlord Member
    771
    15
    You got it right..
    You never no it could just turn off. But other wise it will need a program to turn it off.
