Ahhhhhhhhhhhhhhh my head
big_mo Oct 13, 2009
  1. big_mo
    big_mo MOSES
    137
    Right guys i have had it
    I want to know some thing and i want it stright lol
    I had a............ heated debate about TURBOS
    Right i have an A3 1.8T 20v DBW Y reg. Its a standard turbo that came with the car....................................What is it?????????
  2. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    K03 surely
  3. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    dito
  4. Imteyaz
    Imteyaz 6th Gear
    535
    KO3S (Y-plate is 2000/2001?) although a definitive way to check is to read the part number off the turbo and cross check it to see exactly which one is fitted. The local stealership can also assist, if you ask nicely for the part number based on your registration number.
  5. NHN
    29,577
    1,779
    K03 from what I've read.
  6. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Facelift were around late 2000. If you have a facelift model I thought it would be a K03S.
  7. Broken Byzan
    13,237
    466
    150 bhp FWD cars were K03 turbo'd. It was only the TQS and Golf anniversery that got the K03S to give 180 bhp
  8. Gareth_RS3
    Gareth_RS3 Member
    125
    Would have come from the factory with a ko3 bud for sure doesnt matter if it is a facelift or not.
  9. Imteyaz
    Imteyaz 6th Gear
    535
  10. 1animal1
    9,978
    definately KO3.....the quattro is KO3s and is 180bhp..... yours is definately 150bhp and so KO3
  11. Imteyaz
    Imteyaz 6th Gear
    535
    I've just called my local TPS and asked them the part number for my turbo based on my registration number (Y plate A3 1.8t FWD, DBW, engine code AUM), the part number they gave was: 06A 145 713F, they said that the same part number is listed for the AUQ engine (A3 TQS).
    VAG Cat came up with this though:
    http://www.vagcat.com/epc/cat/au/A3/2000/201/49/2397109/
    O6A 145 713D (not 'F'), still listed as KKK, AUM/AUQ.
  12. big_mo
    big_mo MOSES
    137
  13. big_mo
    big_mo MOSES
    137
    Yeah mine is a DBW and also a facelift................ I said to my mate i have a KO3 but he is aderment that it is a KO3S
  14. Essflee
    Essflee Well-Known Member
    2,154
    67
    I would of guessed at K03s turbo, dbw was only on the face lifts I believe...hence being a K03s...
  15. Imteyaz
    Imteyaz 6th Gear
    535
    I don't know how accurate the list is though.....
    There is a visual difference between the 2 turbo's, something about the number of blades on the impeller (8 blades on KO3S v's 12 blades on KO3). I'm sure someone will come along soon and clarify that.
  16. Essflee
    2,154
    67
    Just noticed your signature, you have a Custom Code map, do you know your bhp figure, if you broke the 200bhp mark then you most definately have a K03s turbo,
    I believe you have...
  17. big_mo
    big_mo MOSES
    137
    Well i had it done by Storm in Reading and there rollers are out buy 20-30bhp so i have heard. It said it was 230bhp so if thay are out im there or there abouts
    Cant realy say any more on thay mate
  18. Essflee
    2,154
    67
    There you go then, definately K03s...
    You'd be no where near those figures with a K03, some peeps have seen 230ish with the K03s...
  19. Lee Goodall
    Lee Goodall Active Member
    2,279
    As somebody said above.. why not just read the tag on the turbo to get the code and then it's easily identified? Simple.
  20. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    It aint THAT simple on an A3. There is no room to get your head down to read it.
    However, the later 1.8T 150/180 both came with K03.053/053 i believe. the 'S' designation is made up and doesnt actually say that on the turbo. I believe the earlier K03 was a K03.011 or something.
    i know for a fact the AUM was a K03's'
  21. Lee Goodall
    2,279
    Yeah if you could visually check the plate on the turbo it wouldn't actually say K03S as stated above but you could cross reference your findings to see if it is what we term as a 'K03S'.
    No room to get a small mirror in there to get a glimpse at the plate either?
  22. RichA3Turbo
    5,089
  23. JS1500
    JS1500 Howdy
    1,166
    10
    Good info there! Cheers for posting it.
    But really, K04 should not produce more than 220hp?
  24. RichA3Turbo
    5,089
    I think he means a K04.001 which is not much better than a K03
  25. JS1500
    JS1500 Howdy
    1,166
    10
    Ahh, ok.
    What's the one fitted to the S3 (BAM)?
    :icon_thumright:
  26. RichA3Turbo
    5,089
    Not a K04.001 or k04.015... lol
    Sorry, not sure of the code.
  27. Westy
    Westy Well-Known Member
    17,443
    1,105
    This thread its getting quite confusing :think:
