AHHHH MULTITRONIC PROBLEMS
jakeA42T Nov 2, 2011
  1. jakeA42T
    jakeA42T Member
    90
    Sh**t here i was driving alone at 70 ish all of a sudden it she bucked, red lined and PRNDS started to flash AHHHH! 10 minutes later nothing, no flashing lights its like she threw a wobbly for some reason, It's done 44,000 last serviced 37,000 with a oil change between. I read a few posts about ECU or Gear Box replacing but I have not had any of the juddering or problems selecting gears found somewhere which said it could be the speed sensor (and how to clean it but for the life of me I can't find it anymore) Im hoping a gear box oil change would sort or help?
    2005 A4 2.0T Fsi multi:uhm:
  2. viceroy
    viceroy Active Member
    284
    76
    run a scan with VCDS and see what errors have been thrown.
  3. paultaylor
    paultaylor Member
    294
    I have a 2004 1.8 A4 Convertible with PRNDS flashing, seems to drive ok, I scanned it and the following errors showed
    Is it a case of a new gearbox ECU?
    thanks
    Paul
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 909 518 AL HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0003
    Coding: 0011584
    Shop #: WSC 00672 785 00200
    VCID: 7AFFF6DB4E1F
    1 Fault Found:
    16891 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 8E0 910 155 K HW: 01J 927 156 HH
    Component: V30 01J 1.8l5VT RdW 3120
    Revision: 00000004 Serial number: 00000000498645
    Coding: 0000001
    VCID: 2D550D87CFD1
    2 Faults Found:
    18201 - Transmission Output Speed Sensor 2 (G196): No Signal
    P1793 - 000 - -
    Freeze Frame:
    RPM: 2304 /min
    RPM: 1536 /min
    RPM: 110 /min
    (no units): 3.0
    Torque: 128.0 Nm
    Temperature: 64.0°C
    T.B. Angle: 30.0°
    Bin. Bits: 1010 0 0
    17090 - Transmission Range Sensor (F125): Implausible Signal
    P0706 - 000 - -
    Freeze Frame:
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04499
    Shop #: WSC 00672
    VCID: E5C535A757A1
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AC
    Component: A4 Klimaautomat 1323
    Coding: 00100
    Shop #: WSC 00672
    VCID: 62CFAEBBC68F
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 00672
    VCID: 326F1EFBD6EF
    Address 15: Airbags Labels: 8H0-959-655-84.lbl
    Part No: 8H0 959 655 B
    Component: Airbag 8.4EC 2015
    Coding: 0011104
    VCID: 397D29D70B99
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 02121
    Shop #: WSC 00672
    VCID: 3E773ACB12B7
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8H0 920 950 G
    Component: KOMBI+WEGFAHRS. RB4 D22
    Coding: 00401
    Shop #: WSC 00120
    VCID: 306B14F3D8E3
    WAUZZZ8H34K019841 AUZ6Z0D0018804
    Address 26: Auto Roof Labels: 8H0-959-255.lbl
    Part No: 8H0 959 255
    Component: VSG B6 CABRIO 6286
    VCID: F3E15BFFE975
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8H0 959 433 F
    Component: Komfortgerát T3B 3220
    Coding: 06784
    Shop #: WSC 00672
    VCID: 37792FEF3D8D
    Subsystem 1 - Part No: 8H2959802
    Component: Tõrsteuer.FS BRM 0003
    Subsystem 2 - Part No: 8H2959801
    Component: Tõrsteuer.BF BRM 0003
    Subsystem 3 - Part No: 8H0959801A
    Component: Tõrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8H0959802A
    Component: Tõrsteuer.HR BRM 0002
    1 Fault Found:
    00955 - Key 1
    35-10 - - - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 M
    Component: symphony II NP2 0410
    Coding: 13005
    Shop #: WSC 00000
  4. g12
    g12 Member
    43
