AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
<tuffty/> Jul 10, 2009
  1. badger5
    9,317
    1,889
    oh its savage all right.. spins all 6 gears at any time in dry on full chat
    Castle combe class B saloon car (but road legal)
    cheers
    bill
  2. quattro rob
    quattro rob Member
    84
    finished off today got it pressure tested by a friend and its fine, both pipes sit level with bumper and sit back a little so dont stick out
    Only problem now is i think the turbo gone as it making a noise which it did before but i thought i had a leaking boost pipe so cracked on with the front mount hoping it would solve it, it hasnt so can only think its a new turbo time gonna take tip of on sat and have a look see ifs it damage in any ways etc
  3. flatshifter
    flatshifter Member
    40
    Hi everyone, Im new here.
    First and foremost great thread. I was wondering if you guys have pictures of the intercooler piping for the hot side(ie compressor's outlet to intercooler), more specifically where the pipe goes from the LH underside of the car.
    thanks in advance.
  4. jeff d
    jeff d New Member
    19
    what is the bnefit of relocating the dump valve, thanks in advance
  5. quattro rob
    quattro rob Member
    84
    finally all finish took a while to get pipe sitting right but happy with it overall
  6. Reekyboy
    Reekyboy 1.8T
    Alright everyone, im just wondering if you need to buy a new hose from intercooler to the throttle body? or if you can use the existing?
    any other tips and advice when fitting it would be handy, thanks
  7. quattro rob
    quattro rob Member
    84
    can use existing 1 m8, the hose i fitted is the cold side kit from forge vbut you dont need it
  8. loafofbrett
    loafofbrett Member
    40
    I got the turbo revs kit, wasn't ready for the lack of MAP sensor + N75 take off mounting points. Got someone to weld a flange for the MAP and made a t-piece to sort the N75. As people have pointed out, I wasn't too impressed with the pipes sticking out like a sore thumb either, so I wrapped them in black silicon, looks better IMO :icon_thumright:
    Pic of it fitted in engine bay...
    Anyway, I'm wanting to return the car to standard now, so the entire kit will be for sale if anyone wants it?
    I'm also after the original hoses from the system if anyone wants to sell theirs? I butchered mine stupidly so don't have them anymore. So if anyone's fitted a kit and has some spare I'll gladly send some money your way :icon_thumright:
  9. MIKE GTR
    MIKE GTR Member
    366
    I've got a forge front mount on mine. My question is, is it right that the 2 standard intercoolers remain either side and that the forge just sits in line or should the 2 standard ones be removed?
  10. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,244
    349
    The two standard SMIC should be removed i think. So you now have three intercoolers! lol
  11. 1animal1
    9,976
    remove the standard ones or else you'll have a biger surface area resulting in increased unecessary lag....plus the FMIC will do loads more than both the other two so they really arent needed....ALSO you'd be extremely lucky if you could fit the FMIC with them inline as its too tight for the FMIC on its own....only one person has managed to keep the drivers side one, but he went to forge and they customised a golf cooler..... not needed though so stick to just the FMIC
  12. MIKE GTR
    MIKE GTR Member
    366
    Its there already, fitted, with both the standard ones still there. It was on the car when i got it and i must admit i thought it strange, the car isn't laggy at all but there must be a pressure drop
  13. 1animal1
    9,976
    ah sorry fella, misread what ya wrote..... thats strange.....bit of a weird pipe set up? or have the fogs gone?
  14. MIKE GTR
    MIKE GTR Member
    366
    Nope front fogs are there and it fits ok, not the best i must admit, but its in no probs at all
  15. MIKE GTR
    MIKE GTR Member
    366
    U can see it a little bit in this pic
  16. Reekyboy
    Reekyboy 1.8T
    Hi everyone,
    does anybody know have pictures of the n75 valve or any information on how or where is best to fit it?
    any info it helpfull
    cheers
  17. Prawn
    11,354
    3,191
    No pics mate, but you need an 8mm brass nipple that you can just drill and screw into the pipework for the N75 take off. Then just seal it up with some chemical metal to ensure it's air tight (the pipes are pretty thin so it doesn't really 'thread' nicely.
    Fit it wherever you like really, although it's generally thought that the closer to the turbo the better the response Stick the first pipe onto the turbo, take a look at what you've got and decide where's best. I put mine about 3'' up the pipe, facing towards the drivers side to avoid any clearance issues around the tight TIP side.
  18. quattro rob
    quattro rob Member
    84
    i took mine to a alloy welder near me, cut off and blanked were the dump valve should go and welded a 8mm nipple to the other side, pressure tested and it holded 30 psi fine all for the sum of £15, job done
  19. Reekyboy
    Reekyboy 1.8T
    Ok cheers lads, I think what im going to do is use the piece of pipe thats on the first fmic pipe coming off the turbo, just reduce the hose pipe size to fit. As im fitting a cold side kit at the same time, shud be alright.
    Any body got any info on a gd boost gauge and boost controller my mate got a £15 EBAY one it works fine.
  20. ALPINE
    3,093
    loving the work on all these cars. but 1 thing i dont understand is why do you all go for massive sized intercoolers when less than half of it is exposed to a direct air flow? Surely if you had smaller sized intercoolers (with the same depth core) you would not only save your self money, reduce lag (all be it by a tiny amount), but still have the same effect as those big jap intercoolers you are all fitting??
    Sorry to sound a gimp but but i honestly dont understand why? it seems a waist of a huge intercooler to me.
    just for the record i apreciate the work involved.. I know hands down they can be a pain to fit!
    sits back and waits for a grilling..
  21. 1animal1
    9,976
    nice to see a little tussle now and again :)
    My opinion as a consumer is that Forge appears to produce quality products, however i would catagorise what they do as over kill with charging to match..... I am a firm believer that you get what you pay for, but because Alex's cooler is cheaper does not automatically mean the Forge item is better...... the only way to be conclusive is to test side by side which isn't realistically gonna happen.....
    Essentially with the majority of applications on this site in particular, I dont think your looking at the market where we are trying to push every last bit of flow through......i for one would trust Alex's judgement based on his experience in this field for the sake of making the seemingly huge saving over the Forge item - one of the major selling points of the Forge item is that it is a 'kit' which you would think would mean it would be 'easier to fit' - the past few fitments however haven't gone together as smoothly as i would personally like to enjoy after parting with such a ridiculous sum of money - AH fabrications for me once i've decided to part with my cash :)
    Tim
  22. AHFabs
    AHFabs Guest
    You will notice that there is a certain height to the intercoolers that does not correspond to the air inlet hole. They have to have the height to allow enough cooling air tubes for the required mass air flow to produce the power.
    Large frontal area will always be preferred over a smaller frontal area using a thicker core because the air speed needed to go through a core over 60 mm thick will need forward speeds to average 90 MPH average to work properly.
    If the core is designed properly, there will be gains in cooling by radiation and even the reduced air speed around the intercooler will still take heat away if the core is made with rows light enough not to suffer from heat soak.
    Cheerz,
    Alex.
  23. SteveBAM
    SteveBAM Black '03 S3
    180
    now this is an awesome thread, just read through the hole thing.. TOP JOB to all of you who have contributed to it....I am really enjoying this forum..:thumbsup:
    Alex(AH Fabs) is there anyway you could ship one of those intercoolers over to Greece? could I pay through paypal?
    thanks
  24. AHFabs
    AHFabs Guest
    Hi Steve,
    Yes we can send it to you, if you send me your full address details, I will be able to get a carriage price to you. Pay pal will be no problem. My email address is: ahfabrications@mac.com
    Cheerz,
    Alex.
  25. S£
    S£ Member
    683
    Alex
    Do the intercoolers come with mounting brackets welded on or is that something we have to do? Also is the price still the same as tuffty mentions in the first post, £250
    Sam
  26. SteveBAM
    180
    ok thanks Alex i will contact you soon..:icon_thumright:
  27. AHFabs
    AHFabs Guest
    Hi Sam,
    It will come with the fixing brackets welded on, and the price is still £250.00 + £15.00 delivery if payment is done as a gift in Paypal. If you send me your Email address I will send a photo.
    Many thanks,
    Alex.
  28. s3gav
    s3gav Member
    413
    got home from work today sun was shining so thought i would start fitting my forge fmic.
    and i must say well worth the money imo everything went straight on where it was ment to the bumper went on first time which i was very supprised after other comments on this kit, 100% happy with things so far
    will post some pics when ive finished as none of the hoses are secured yet
  29. djdougalno1
    djdougalno1 Member
    189
    this is an ebay intercooler kit for lcr i brought cost me 200 quid tiged welded 2 brackets on fitted like a dream was a bit wary about its perfromace but amd told me it worked spot on when they mapped the car kept the temps down and had good flow
  30. Forge
    Forge Member
    204
    Gav ...,glad you liked the Forge intercooler , regarding the ebay cores ...there is some good info over on seatcupra.net posted by Rob Don that will show that some of the ebay core are less than efficient when it comes to the actual cooling ....its all about choice tho
  31. 1animal1
    9,976
    any chance that you will bring the cost of yours down Forge? owing to the fact that i can source an AH and pipes for sub £400, £250 for convenience is one hell of a premium still :)
  32. Forge
    Forge Member
    204
    The Forge kit is designed as straight fit , it includes a new crash bar already cut and modified to accept the Forge intercooler ....I can offer you a discount off the RRP
  33. MIKE GTR
    MIKE GTR Member
    366
    forge, am i losing efficiency by having both the std coolers and your forge cooler working together
  34. Forge
    Forge Member
    204
    I would imagine so yes m if you are on a standard turbo , I would thik that you will be getting a lot of pressure drop ... our developed intercooler was taking into consideration the removal of the oem parts
  35. MIKE GTR
    MIKE GTR Member
    366
    Its got a k04 hybrid, but to be honest it keeps blowing the hoses off the intercooler joins, so there appears to be a presure build up at these points. do u sell the end pipes on their own and if so how much?
    many thx
  36. Forge
    Forge Member
    204
    sorry we only seel the Forge kit as a complete kit
  37. MIKE GTR
    MIKE GTR Member
    366
    OKey doke cheers.
    The original owner of mine must have binned those lol
  38. s3gav
    s3gav Member
    413
    totally spot on less than an hour i had the old stuff off and new stuff test fitted bumper whent straight on then i ran out of light lol
    will hopefully have the car back 2gether in no time and it was done in my little garage without jacking the car up
  39. tompearson
    tompearson It's all in bits
    219
    Spent some time this afternoon getting my car ready to fit my AH Fabs FMIC. The plan was to get the crash bar measured up so I can take it to my mates workshop and get it cut tomorrow. Anyway I took the bumper off and decided to remove both SMIC and their related pipe work. I then moved the horns and got the crash bar off so that everything was out of the way and I could offer up the FMIC to see what would needed to be chopped out.
    However it then struck me that my S3 (99 APY) is completely different to all others I have seen (without the bumper on at least) as I have a naff looking silver rad, which has a ruddy great fan bolted on the left of it, and what looks to be some component of the AC strapped in behind the crash bar on the right.
    What seems strange though is that on the back of the radiator there is a circular shaped hole that looks like it should have fan in it but that doesn't - well there are 2 holes, but one does have a fan in.
    Has anyone else come across this arrangement and can offer some tips? I am hoping I should be able to fix AC thing somewhere else but I'm not sure what to do about the fan as I don't think I can clear it.
  40. badger5
    9,317
    1,889
    someones been bodging on your car
    front fan aint std. 2 fans on back is
