AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
<tuffty/> Jul 10, 2009
  1. <tuffty/>
    20,896
    3,705
    I'll be there :)
  2. JoeD
    JoeD Member
    537
    10
    Cheers Tuffty. So your saying I should have the following contents of the list bellow, and what I don't have I will need, in order to install and it should be pretty straight forward once I have those peices?
    2 x 51mm 45deg silicone elbows
    2 x 60mm to 51mm 90deg silicone reducers
    2 x 51mm 45deg aluminium pipes
    2 x 60mm aluminium hose joiners
    1 x 60mm hose piece to replace short piece off MAP sensor tube (optional)
    6 x 54mm-62mm clamps
    7 x 67mm-75mm clamps
    1 x 73mm-81mm clamp
  3. JoeD
    JoeD Member
    537
    10
    Can anyone with a Forge FM confirm which size pipes are needed? Just about to go ahead and order the above.
  4. Scullies
    Scullies Well-Known Member
    1,543
    657
    I received my cooler and 3" piping.
    Fitted on over the weekend, original fogs are out of the picture, but aftermarket LED ones to be fitted.
    3" runs from charge pipe all the way through to the map sensor pipe.
    Cooler is a fin and tube number and its pretty light weight.
    No temps logged yet as its 48deg and not to keen to push the car in this heat.
    KIT - quited a few pipes left over. Only used the 2x 90deg and the 2x U shape( cut to fit )
    Fitted
  5. Paradox1
    Paradox1 Active Member
    1,833
    88
    Can anyone tell me if a wellycooler is too much for a k03s turbo setup?
  6. superkarl
    superkarl MAN OF STEEL
    9,404
    2,378
    define too much?
    more than enough, yes.
    but you will have epic iat's
  7. Paradox1
    1,833
    88
    Just got my wellycooler,the thing is friggin massive!
  8. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    i second this, i got mine the other day and im even thinking how the hell does this go on the front of an a3/s3
  9. Paradox1
    1,833
    88
    Angle grinder springs to mind!.if you do yours before i do.get some pics up please.more the better
  10. Westy
    Westy Well-Known Member
    17,443
    1,103
    Yeah it's a beast. The core itself isn't a struggle to fit between rad an bumper, it's the inlet and outlet that's a pain.
  11. Paradox1
    1,833
    88
    It's going on a mk4 gti aswell,I'm sure there's less space than a s3.will be a struggle eitherway lol
  12. mmcrew
    mmcrew New Member
    Hi guys, im a complete noob to the turbo world and FMIC`s , Iv got a a3 quattro and im looking to buy a FMIC soon, for looks aswell as i want my car to pull like a train (i know i need atleast a remap too) but ive been scouring the site for info and ive kinda got the general idea on how to fit these but im still confused one where one pipe goes.
    i understand one pipe attached to the block on the front of the engine (the pipe that flows down the drivers side of the car) but i cant get my head around where the other end goes and i cant seem to see any pics of peoples builds, I can see if going over the top of the engine and down to the back, but after that im lost.........
    I thought it would of gone where the TIP connects but theen that wouldnt make sence and make an air box useless,
    Can anyone help and give me a bit of an idea guys
    Lee
  13. Sam_
    Sam_ Down under
    3,035
    480
    A bit of feedback on the AH Fabs V2. With ~3c ambient at the weekend (down in the snow), AITs were getting down to that (3c) on boost (around 6-7c off boost), believe it or not. Pretty bloody good.
  14. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Got the intercooler fitted today. Not as much of a job as i thought.
    Had to scrap around to find some nuts for the bonnet catch and mess around with the horn bracket. But all done in a bout 2.5 hours.
  15. JtotheD
    JtotheD Active Member
    907
    26
    hopefully attempting to fit my ah v2 today. try and post some pics up later! :).
  16. g60leigh
    1,674
    207
    I have re-read this post and cannot find the answer. Sorry if it's covering old ground.
    I have an ah fabs v1 cooler I picked up second hand and have it all installed no problem.
    The only thing is the top hose visible on the driver side is red.
    I know all the hose sizes are listed but not exactly sure which is which.
    I am wanting to replace it with a black one for a more oem look.
    Also would like to replace the one on the passenger side that comes up from under the battery area to the inlet manifold/throttle body as this is currently a standard tapered hose.
    Please can anyone tell me what size and angle hoses are needed.
    thanks
  17. <tuffty/>
    20,896
    3,705
    Forge do replacements designed for this... there is no list for these parts as generally there is no need for custom ones on the S3
    Forge Motorsport | Alloy Fabrication
  18. g60leigh
    1,674
    207
    Thanks again for your help and rapid replies Tuffty.
    I noticed on your guide you had THS ones
    Where these from a kit as the forge ones or part of the eBay order?
  19. Prawn
    11,413
    3,302
    They fit boys, just need to man up with the grinder :)
  20. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Just looking on eBay and there's a 600x300x100mm Fmic on there which is obviously bigger than the 76mm Wellys cooler. Would this be over kill?
    Ive removed the aircon on my latest project so got more room to fit the thing but no point in doing it if the pressure drops going to increase or it's not worth it. Any ideas ?
  21. <tuffty/>
    20,896
    3,705
    The THS ones I have are pretty good tbh... they don't seem to be available any more now though...
  22. Paradox1
    1,833
    88
    Dan, its way too big stupid me ordered one by accident. It was litterally longer than the crash bar.how the hell it would fit behind s3/a3 bumper I doubt it.
    Remember that 800bhp s3 on YouTube. That cooler isn't much different in size to the welly cooler so i dont think there woyld be much point in going bigger to be honest.
    Nick at r tech is running a core for the a3 fmic and that's running 340+ last time i checked.
  23. coatesy
    1,920
    280
    haha this is how it went on grinder/hammer/drill. 310% man way of doing anything.
    here is mine fitted still need to take a picture with the bumper on.
  24. Paradox1
    1,833
    88
    I'm getting the right size cooler next week so ill join the man up club for sure. not sure how much crash var i will have left though lil
  25. beachbuggy
    1,931
    201
    I was just wondering as the length and height where the same but it's 1" deeper and with the aircon removed I had more space, I'd imagine it would be over kill and theres a lot more to fill being a bigger volume. It's going in a TT anyway do there is more room behind the bumper.
    Also is there any benefit running 3" ic piping over 2.5" from turbo to throttle body ?
  26. beachbuggy
    1,931
    201
    Do you still the other fmic? Where abouts in the south east are you?
  27. Paradox1
    1,833
    88
    I think 3 would be better than 2.5 for perhaps a bug turbo setup but i think 2.5 pipes is more than adequate for what we need.
    No sorry i returned it mate. I got it off eBay from 1stcar parts. About 88 delivered. Check them out mate
  28. <tuffty/>
    20,896
    3,705
    2.5" or 63mm is plenty big enough for most peoples needs... Bill still runs 63mm pipework on his Ibiza currently at 550hp...
  29. Yohan87
    Yohan87 Member
    426
    12
    With regards to the pipework diameter, are you best to have as little 3" pipework as possible and only step up/down at the inlets/outlets of the cooler?
    Or is it better to step up at the charge pipe outlet?
    Or does it make bugger all difference (performance / flow wise)?
  30. <tuffty/>
    20,896
    3,705
    Welly runs a 3" setup IIRC... but not sure where he steps down to 60mm for the std pipework...
    3" would arguably induce lag as there is more area to fill over a given time period and velocity will be down so might affect torque...
    63mm is plenty big enough so its more down to fitment... if it were me I would use 63mm as much as I could
  31. Yohan87
    Yohan87 Member
    426
    12
    That was my line of thought as well.
  32. g60leigh
    1,674
    207
    Cheers mate.
    So I'm assuming any silicone top boost hose kit will still fit.
    I was guessing that they were just for the smic and a fmic would be different.
  33. <tuffty/>
    20,896
    3,705
    Yeah, any of the kits available will be suitable...
  34. g60leigh
    1,674
    207
    Guess I was just thinking it would be more complicated than it is. Sorry mate.
  35. <tuffty/>
    20,896
    3,705
    all good dude :)
  36. g60leigh
    1,674
    207
    Cheers bud. You really are one of the stars of the show.
  37. knoxie
    knoxie K4OXE
    619
    15
    hi guys anyone know the thread size for the four mounting holes on the welly cooler? i think its been covered on here but cant see it :(
  38. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    Iirc they're M10 :)
  39. StaceyS3
    2,489
    473
    Actually sorry looking at a pic I've got they look like M8's
    Best someone else confirms it ;)
  40. <tuffty/>
    20,896
    3,705
    M8's :)
