AGU K03s + injectors
darnich Mar 20, 2006
  1. darnich
    darnich Member
    106
    I plan to upgrade to a K03s turbo and just found an interesting deal
    what I don't know for sure is if I can use the injectors
    their part no is
    Bosch: 0 280 156 061 or
    VAG: 06A 906 031 BA and are of the EV6 type
    as far as I know the AGU engine uses the 06A 906 031 EV6 type injectors
    can anyone help?
    Thank you
    Kostas
  2. HTC
    HTC Active Member
    3,428
    9
    Those injectors are for the later 150bhp/180bhp DBW engines. AUM/AUQ etc.
    They are slightly longer than your current AGU injectors. They are not a direct fit. You need a spacers for the fuel rail to fit them. But you don't need these items for your plans.
    I am running my K03s with standard injectors. Only difference is I use a 4bar fuel pressure regulator to up the flow for top end. Works fine.
    If the injectors are part of a kit, you could perhaps buy them and then sell them on again?
  3. darnich
    darnich Member
    106
    Ok thanks!
    I will probably go for a 4bar FPR instead of the injectors
    I know that I also need the TIP (turbo inlet pipe) from a newer model one with a K03s
    does anyone know the the OEM part number for this item?
  4. darnich
    darnich Member
    106
    Finally I went for the injectors as well.
    The kit is off a car with only 3000 miles on it and it is only 5 months old.
    I got the whole lot for £250.
    However I need a TIP (turbo inlet pipe) from a model with a K03s
    does anyone know the the OEM part number for this item ?
    I think it is much cheaper than a silicon one....
    Can somebody help me?
    Thank you
  5. darnich
    darnich Member
    106
    I could also use an estimate on its price
    thanx again
  6. dummi
    dummi smoking a6
    1,210
    be good idea to get turbo checked before you put it on by a specialist, i bought a pair of k04's of ebay a while ago told they had done 15000 miles, thought i'd get them checked anyway as its a pig of a job, turned out they had the wear of 80000miles lol, needless to say i was glad i spent £40 for them apart and £200 each for recon i got them at a low price anyway
    good luck
  7. darnich
    darnich Member
    106
    I plan to do so....
    good point!
    Anyone with a part number?
    Does the AGU samco TIP fit on the K03s?
  8. HTC
    HTC Active Member
    3,428
    9
    The Samco TIP is a perfect fit onto the K03s inlet. This is what I have at the mo.
    I will try to get a part number for the OE metal item for you. The catalogue is a bit vague as to which is the correct part. I've got one in my garage so I'll take a look later if nobody else posts.
  9. darnich
    darnich Member
    106
    I am afraid that the Samco TIP is going to cost as much as turbine itself....
    once again thanks
  10. HTC
    HTC Active Member
    3,428
    9
    I'm having trouble finding the part number for you. I took a look at my old inlet pipe for the smaller K03. The lower metal part has a number that couldn't be found in ETKA which I thought was a bit weird.
    I did find a number but I think its for both the rubber and metal sections together. This is for the K03s and is 06A 133 354D. It £67 + vat over here. Not sure how much it would be for you.
    I rekon you should call you local dealer to see if they can get the number for just the metal part as it should be alot cheaper.
  11. darnich
    darnich Member
    106
    Thanks a lot!
