Ste_Nova
Ste - still not legal -
why not? it can't be fitted with washers or leveling, and they don't make any other headlights that could be fitted as all s2000's have hids
are you saying every imported s2000 is illigal?
There may be some allowance for imported cars, since they deviate from UK/EU manufacturing specs. Some aspects need to be met (ie addition of a rear fog light) to pass the SVA (or TUV or IOU whatever the damn test is called) which imports are subjected to, it's been a while since I owned an import so it's a bit hazy.
I'm now pleased I didn't mention Regulation 42 of the Road Traffic Act 1988 or Regulation 18 Road Vehicle Lighting Regulations 1989 as this would have really got people confused!
Road Traffic Act 1988:
Regulation 42
Breach of other construction and use requirements.
A person whoâ
(a) contravenes or fails to comply with any construction or use requirement other than one within section 41A(a) or 41B(1)(a) [F2or 41D] of this Act, or
(b) uses on a road a motor vehicle or trailer which does not comply with such a requirement, or causes or permits a motor vehicle or trailer to be so used,
Obligatory lamps, reflectors, rear markings and devices - Regulation 18.
â(1) Save as provided in the foregoing provisions of these Regulations and in paragraph (2), every vehicle of a class specified in a Table in Schedule 1 shall be fitted with lamps, reflectors, rear markings and devices whichâ
(a)are of a type specified in column 1 of that Table, and
(b)comply with the relevant installation, alignment and performance requirements set out in the Schedule or Part of a Schedule shown against that type in column 2 of that Table.
(2) The requirements specified in paragraph (1) do not apply in respect of a lamp, reflector, rear marking or device of a type specified in column 1 of a Table in the case of a vehicle shown against it in column 3 of that Table.
(3) The requirements specified in paragraph (1) apply without prejudice to any additional requirements specified in regulations 20 and 21.
(4) The Schedules referred to in the Tables in Schedule 1 are Schedules 2 to 21.
Slightly off-topic... doesn't ECE Regulation 48 allow for flashing brake lights when decelerating above a certain G (some UK spec Mercedes C class and Volvo V70 have this feature)?the US-spec Corvette brake lights flash when braking and the UK regs say that the rear brake lights must all be constant, steady light
^^agreed^^ its the non projection and not set up correctly lights that should be banned
