Aftermarket sterio install
SteVR Mar 18, 2010
  1. SteVR
    SteVR Member
    51
    Hi guys I am planning on fitting my becker head unit into the audi. It has the rear amped speakers but I will be replacing these with a set of infinities I have lying around. I ve read that its best to run new rear cables and not use the iso leads with the rca option. So my question is which iso lead do you guys recomend I use?? one for a non amped system then splice in the rear chanels? any help of pointers would be great
    cheers
    Steve
  2. aragorn
    18,491
    855
    you shouldnt really need any lead?
    The Audi already uses a standard ISO plug, the only oddity is the 12v ignition switched feed is missing on some cars.
    I guess it might make it a bit easier to add in the rear cables if you buy some kinda lead though, but the nicest solution would be to buy some extra pins for the existing plugs and just add the wires there.
  3. Geeman
    Geeman Low Life
    1,318
    I had to completely re-wire my whole stereo system in mine... it was a right mess! It's not too hard to route new cables to the rear...
  4. SteVR
    SteVR Member
    51
    Doh me being a dime bar!! that all makes sense.
