Aftermarket Stereo
Verne Aug 26, 2008
  1. Verne
    Verne New Member
    22
    I need a little help with the stereo system in my 2.8SE Avant
    The original Audi Concert stereo has the common deafening volume problem and after speaking to several people I have decided to replace it with my Pioneer CD head unit that I had in my Honda. This brings up a couple of questions.
    Firstly, with the difference in the sizes of the stereo, I'll need a facia plate and so far I have managed to find 2 kinds (below)
    [​IMG] [​IMG]
    Which is correct :uhm:
    Secondly, it depends whether it is the Bose system as to which wiring adaptor I need. How do I know whether it's got the Bose system and will all the extra wiring fit behind the dash, as there seems to be a shortage of space and a lot of wires.
    Without Bose
    With Bose
    TIA
  2. matt_o121
    matt_o121 2.8Q
    84
    your radio will say bose in the display when turned on and the lower door speaker grills will have bose logos too.
    the difference between the leads is the bose system runs via pre out only all channels are externaly amplified.
    the normal system has amplified rear speakers and requires the other lead.
    i purchased the lead and the facia panel - i bought the two piece adapter, which worked fine,
    i decided i did not like the aftermarket stereo fitted though, the flap did not shut, and the unit stuck out and looked wrong. - a fold out monitor, dvd player, tv and nav hidden away.
    i replaced it with a nav plus unit, although looking back this ended up costing in excess of £500, and although i love it, it was more than i would spend - i got the radio new from a dealer for £220, so the mounting parts etc are the main cost-
    does the pioneer illuminate red? if not it will stick out in your very red interior.
    matt
  3. Verne
    Verne New Member
    22
    The stereo isn't red, but gonna give it a go as it's the cheapest option.
    Going to rewire myself to save have a mountain of wires to force behind the stereo, so does anyone have a proper wiring diagram to explain the label below.
    TIA
  4. matt_o121
    matt_o121 2.8Q
    84
    TIA[/quote]
    i take it you are handy with the wiring then??
    it would be so much easier to use one of the looms above, but i can give you a starter for 10...
    you have the two basic iso plugs - black and brown if i remember correctly, black is the power plug and the diagram above is the top one.
    first pin on the left is the earth, the sun next to this is the illumination,
    s cont is shown as a memory positive connection
    mute - mute
    ub+ permant live, next to that the switched live feed from the ignition.
    k bus i believe is the lead to the dash to display the radio station etc on the dash.
    ga - is the gala input for the speed dependant volume.
    below this the speaker outputs - brown plug positive and negitive for left and right front speakers.
    below this is a long plug made of three coloured sections - you only need to bother with the one on the right - rr,lr and com are the low level speaker connections with another switched positive from your head unit to turn on the amp.
    the large red plug on the side is only used for aditional connections for example phone kits.
  5. matt_o121
    matt_o121 2.8Q
    84
    there are also better leads than shown above - i have an autoleads pc9-404, this has the two rca inputs to allow you to use your headunits rca out puts for the rear channels.
    you can get these for less than a tenner, they will fit fine and a lot less hassle!
  6. Verne
    Verne New Member
    22
    Thanks Matt :anbet:
    exactly what I need on both accounts. I'll look at the loom before taking everything apart :icon_thumright:
