Aftermarket speaker recommendations for audi a3 8p sportback
amit91987 Jun 18, 2012
  1. amit91987
    amit91987 Member VCDS Map User
    119
    Hi,
    I have realised my rear speakers are not as loud as the front ones. I do not have a Bose set up, so I am considering changing all speakers to aftermarket ones.
    Does anyone know why the rear speakers are not loud as the front ones, by this I mean when I have passengers they cannot hear the music. I have checked all the settings via my headunit- all seems to be fine.
    Also, any recommendations for aftermarket speakers?
    Thanks in advance.
  2. t0ph0id
    t0ph0id Member
    54
    You may want to give a budget otherwise recommendations could be between £80 and £800
    I've just installed some Focal Access A1's in the front, sound is amazing.
  3. amit91987
    119
    Probably between 150 and £250.
  4. amit91987
    119
    Ideally would want pioneers if they fit around that budget. However, would not mind other speakers that are of a good quality.
  5. AndyMac
    9,832
    45
    Are you using the stock HU or aftermarket? Really no point spending that sort of money on rear coaxials driven off the stock 2 x 20w rear amp
  6. Artimus
    Artimus Shortback
    2,014
    483
    rather than upgrading speakers, adjusting the fader setting more toward rear bias and cranking up the volume would achieve a better effect than changing speakers - which would still leave forward bias anyway.
  7. amit91987
    119
    Andymac- i am using an aftermarket unit, the pioneer avh 8400BT.
    Artimus- i have tried adjusting the fader settings, but it seems my rear speakers are very quiet. Is this common for non bose setup?
  8. Artimus
    Artimus Shortback
    2,014
    483
    I don't think it's common on any system! output is usually pretty well balanced on all of them. are you sure you don't have an 'enhanced' output selected on the Head Unit ..i.e: Pop, Rock, Church, Wide, etc??? as this can affect the output levels in multi-channel systems.
  9. amit91987
    119
    I don't think i have selected any enchanced output. The only setting i have messed around with is the different equaliser settings, i.e. superbass, flat etc to see if this made a difference on the rear speakers, which it did not.
  10. Artimus
    Artimus Shortback
    2,014
    483
    In that case I'd recommend checking the polarity of the rear speaker wiring is correct on both sides.
  11. amit91987
    119
    Thanks, I will try and fiddle with the fader settings and if that does not work, I will have to get someone to check the polarity.
  12. AndyMac
    9,832
    45
    No it's nothing to do with settings on the HU. It's because you have twice the power going to the front speakers from the 2 x 50w internal amp in the Pioneer, but the rears are still using the feeble 2 x 20w rear amp inside the subwoofer enclosure.
    You need to rewire the rears directly to the HU which will solve the issue, then reconnect the audi rear/sub adapter to the subwoofer pre-outs on the Pioneer and jack the sub level right up. The sub will still struggle to balance with the cabin speakers but at least you will have balanced rears.
  13. Artimus
    Artimus Shortback
    2,014
    483
    Is there a sub\amp in the non Bose system Andy
  14. AndyMac
    9,832
    45
    Yes the non Bose version has a 50w (peak) subwoofer powered by a 4 ch amp inside the tupperware enclosure with 2ch's powering the rears. The Bose version is 100w (peak) powered by the 6ch amp on the drivers side in the boot, with the other 4 channels powering the cabin speakers
    There were a few models produced with no subwoofer or rear speakers (god only knows why as it's all of £50 worth)
    mister.c. and Artimus like this.
  15. Artimus
    Artimus Shortback
    2,014
    483
    I'm here to learn & stand corrected. Thanks. :thumbsup:
