AFTERMARKET RADIO
Neilb1 Dec 6, 2012
  1. Neilb1
    Neilb1 Member
    178
    Decided i want to install my after market radio.
    is there a how to on removing the standard on and what i will need ie Ariel adapters etc
    I know i need the facial plate adapter but what else
  2. AndyMac
    9,832
    45
    You need the removal keys, insert them with the angled sides facing inwards (towards each other). Once you have the keys inserted they should lock in position but don't pull on them to pull the HU out as you can damage the spring clips and end up with the HU stuck in the dash.
    Remove the glovebox and push the HU from behind.
    You'll need an ISO aerial adapter
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    And a PC9-404 or 410 RCA input adapter depending on whether you have non Bose or Bose. If unsure then use the 410 as it works on both.
    Halfords | Autoleads PC9-404/PC9-410 - Audi ISO Lead/Harness Adaptor
    You will also need to wire in a switched live feed as the B6 doesn't have one at the HU, or wire both red & yellow feeds together to the perm live and switch the HU on/off manually.
    Neilb1 likes this.
  3. Neilb1
    Neilb1 Member
    178
    cheers all bought just wait till they come now
    however i suppose i could take the switched live from the fag ligher could'nt i
  4. slappy
    slappy Member
    205
    Nope, that's a permanent live.
    Take it from the fuse box, use a tester to find a switched live feed and tap into it.
  5. Neilb1
    Neilb1 Member
    178
    yes sussed it out and took it from the fuse box
